R33 GTST 4 piston / spot / pot calipers.
In good working order. Came off my car working, removed due to an upgrade. Still wet with fluid inside. Seals look good. Have been stored wrapped in plastic in a box in the shed.
Complete with pins, shims and cross springs. All good, just need a clean. The short hard lines are attached. I have OEM rubber lines for and R32 if you need. Also removed from my car working, as part of the upgrade.
I have some ~50% used stock (or maybe Bendix Ultimate) type pads that will suit, if you need. No charge.
I have matching 296mm rotors if you're desperate. But they are only just over 28mm thick and will likely go below minimum if they're skimmed. Not worth shipping these anywhere - better off putting the money towards new rotors.
Asking $300 shipped in Australia. Polite offers considered.
https://www.sau.com.au/forums/topic/478862-r33-gtst-4-pot-calipers/
  • 7 months later...
  • 4 months later...
