Hey guys
Is there a difference between the r33 det and de speed sensor as I can't find anything anywhere for the de version. Please post a link to a site or just any help would be awesome as I need the part to get my car on the road :)
I own a 1996 r33 series 2 rb25de manual
Edited by Riley33
https://www.sau.com.au/forums/topic/478863-rb25de-speed-sensor/
I could be wrong but I think there different we done an auto to manual swap on my son's 33 series 2 and the gear box was was from a rb20 and we needed a RB20 speed sensor and cut the plug and used the auto plug, and good luck finding one it took us a few months to get one, ended up finding one on scumtree for 80. I found this link about the boxes
  • Like 1
3 hours ago, Riley33 said:
Hey guys
One would expect the sensors to be different as the diff ratios are likely to be different. But your car will still run with the wrong speed sensor.
  • Like 1
1 hour ago, KiwiRS4T said:
Hey guys
The det unit has 20 teeth and the de unit has 21 teeth but the sensor assemblies are different part numbers also.
the part number you need is 2501071T00  USD 80 plus freight from amayama.
Edited by Rusty Nuts
  • Like 1
3 minutes ago, Blackend34 said:
think the de-t sensor is longer than the de, and doesn't fit, might pay to ring a wrecker and find out for sure, but when I was looking for one I had to specify that it was for a de, that's what niswreck told me anyway
NO just NO, see my reply nothing to do with length.
2 hours ago, Blackend34 said:
Yes that's it. Amayama have the speed sensor but not the drive cog, now just google the part number and you will find other suppliers who do have stock, (Concord parts USA have stock)the 21 tooth drive cog was used on many different Nissans
No-one ever said finding parts for 23 year old JDM vehicles would be easy.
  • Like 1
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
