have a Hypergear 2u1 hiflowed turbo for sale in about 14 days time - will be on the car still until then and any test welcome - is still in excellent condition, probably around 3? years old? Just moving on to a larger turbo now. Has been run around the 15psi range mainly, so well under its' limits. Comes with a Mamba adjustable wastegate that's been modified to PROPERLY fit instead of the usual off-the-shelf shit fitment. Wastegate is under 10 months old and comes with all the extra springs. Will also throw in a metal intake pipe cos why not. $500 for the lot, pickup in Brisbane or postage anywhere in Oz at cost.
Still on car so a pic won't show much, but will post pics once removed if not sold by then.
Also still have - brand new GK Tech subframe bushes for R33 GTST in box, Splitfire series 2 R33 coils, Tein springs brand new in box, TOG R33 hicas eliminator kit brand new still in box, to name a few. PM if interested.
https://www.sau.com.au/forums/topic/478894-hypergear-hiflow-turbo-rb25-2u1/
Hey mate im assuming this will fit a r34 gtt? Im in Melbourne but am definitely interested! Send us some pics of that metal intake pipe and the turbo too whenever you can, thanks!
Edited by R34NeoLover
You will need to do a bit to get the pipe to fit your exact setup; it is a stainless 90 with the ports welded into it. More of a "free gift" with the turbo. I will post a pic shortly.
  • 1 month later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
