OK need some help gurus so riped everything out of my r34 and put in my Chrysler as 34 going ls track but ive ran into a problem runs drives great but I cant get speedo working r34 loom dashcluster the lot in so the wires from r33 elec box speedo White and orange where do they go gbox cluster then ecu?  Seems I've cut something or not plugged in somthing so I've managed to get speed hooked up to my power FC controller but it won't work in cluster or go through cluster speed input to speed output for ecu only works with wire straight from gear box to ecu speed signal any ideas? Is it just one of the box wires that goes to cluster pin 19 or?  Not sure what ive done wrong it was all working n my r34 witch was auto na then converted to Manuel det with original loom but when I put in the Chrysler only lot I really cut was all the wiring going down the center of car n heater n clock etc but just want to direct wire it to speedometer please help me haha
https://www.sau.com.au/forums/topic/478908-r34-rb25-speedo-wiring/
You can search this. But for your benefit, I will type it all out, once again.
Gearbox sender is Sawtooth (AC) +/- 1V signal that goes to the speedo head. Frequency depends on speed.
Separate wires then run from the speedo head to the ECU (actually, it's really only 1 wire) that carries a 0-5V square wave PWM signal where the pulse width carries the speed signal.
Get the wiring diagram out and make it like that.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
