Thanks for more input all, sounds like i'll need to invest in a few more spanners.
As for going to single - good question, i'm here and have the -7's so i'll just forge forward and in years to come can come back and reflect on where it all went wrong on this post...
Any thoughts around the gasket / stud kit - plan is to get the complete one and replace the studs potentially?
Views on the oil restrictor for the '7s?
  • Sad 1
I got the turbos and manifolds off with. Basic set of spanners and a set of kincrome swivel head ratcheting spanners. Those things are super handy for tight spots. You can loosen manifold nuts one click at a time. The secret is to have a ratchet mechanism that is really tight and doesn't have too much angle between ratchet teeth.
  • Like 1
And you also went to a single :)
Moral of the story, every GT-R owner that wants response and power ends up going to a single modern twin scroll turbo.
  • Like 2
Thanks for that, good advice - i've been mindful on the tight spots of getting to everything.
Regarding restrictors, yes the ball bearing cartridges take less oil than the stock bush bearings meaning oil restriction to be used. I have HKS GT-SS / -9s and the oil restriction came in the way of a restricted banjo bolts supplied with turbos. The difference is something like 5mm To 1.5mm, so definitely required.
16 hours ago, BK said:
Regarding restrictors, yes the ball bearing cartridges take less oil than the stock bush bearings meaning oil restriction to be used. I have HKS GT-SS / -9s and the oil restriction came in the way of a restricted banjo bolts supplied with turbos. The difference is something like 5mm. To 1.5mm, so definitely required.
Thanks for confirming Ben - the gasket kit I put on the front page has an option to have a 1.0mm restrictor included in it so will look at getting this when ordering.
Andrew and Michael at Kudos motorsport are great. Yeah mine was the full HKS GT-SS kit with everything included. Looks like Kudos are using the HKS restricted banjo bolts I mentioned in their gasket kit.
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
