Hi all, Ive got an R31 with an RB26 in it with a power FC. Im also running an RB25det gearbox so my speedo is a mile out! at 100 KMH it showing 80 kmh and the stock speedo is never fantastic. I was looking at hooking up the speed signal from the gearbox to the Power FC, and using the speed reading on the hand controller. But, I was wondering can the speed reading be adjusted on the hand controller to be accurate?
I know I can just use a GPS speedo, which I am using my GPS for speed on the car, but id like a better option.
Thanks.
1 hour ago, NismoR31Jet said:
Will it work with the PFC? I bought one of those to try and adjust my original speedo and it didn't work.
I will type this out for the 300000000000668684873276347th time.
The signal from the sensor to the speedo head is a sawtooth (AC) voltage +/-1 volt. The speedo head converts that to a square wave PWM 0-5V signal for the ECU (and every other CU in the car that looks at speed). You have to set the Jaycar jobby up for the type of signal you are correcting, and you can't ever try to direct connect the sensor to the ECU, because they just don't speak the same language.
The Jaycar one, I think, works well on AC signals and not on PWM signals. If you have a need to convert a PWM, the smart approach these days would be to program an arduino to take in, modify and spit back out. Would only take a few dozen lines of code and possibly a variable resistor to allow you to adjust the effect without reprogramming.
  • Like 1
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
