Hi all, Ive got an R31 with an RB26 in it with a power FC. Im also running an RB25det gearbox so my speedo is a mile out! at 100 KMH it showing 80 kmh and the stock speedo is never fantastic. I was looking at hooking up the speed signal from the gearbox to the Power FC, and using the speed reading on the hand controller. But, I was wondering can the speed reading be adjusted on the hand controller to be accurate?
I know I can just use a GPS speedo, which I am using my GPS for speed on the car, but id like a better option.
Thanks.
1 hour ago, NismoR31Jet said:
Will it work with the PFC? I bought one of those to try and adjust my original speedo and it didn't work.
I will type this out for the 300000000000668684873276347th time.
The signal from the sensor to the speedo head is a sawtooth (AC) voltage +/-1 volt. The speedo head converts that to a square wave PWM 0-5V signal for the ECU (and every other CU in the car that looks at speed). You have to set the Jaycar jobby up for the type of signal you are correcting, and you can't ever try to direct connect the sensor to the ECU, because they just don't speak the same language.
The Jaycar one, I think, works well on AC signals and not on PWM signals. If you have a need to convert a PWM, the smart approach these days would be to program an arduino to take in, modify and spit back out. Would only take a few dozen lines of code and possibly a variable resistor to allow you to adjust the effect without reprogramming.
  • Like 1
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
