Hi all, Ive got an R31 with an RB26 in it with a power FC. Im also running an RB25det gearbox so my speedo is a mile out! at 100 KMH it showing 80 kmh and the stock speedo is never fantastic. I was looking at hooking up the speed signal from the gearbox to the Power FC, and using the speed reading on the hand controller. But, I was wondering can the speed reading be adjusted on the hand controller to be accurate?
I know I can just use a GPS speedo, which I am using my GPS for speed on the car, but id like a better option.
Thanks.
1 hour ago, NismoR31Jet said:
Will it work with the PFC? I bought one of those to try and adjust my original speedo and it didn't work.
I will type this out for the 300000000000668684873276347th time.
The signal from the sensor to the speedo head is a sawtooth (AC) voltage +/-1 volt. The speedo head converts that to a square wave PWM 0-5V signal for the ECU (and every other CU in the car that looks at speed). You have to set the Jaycar jobby up for the type of signal you are correcting, and you can't ever try to direct connect the sensor to the ECU, because they just don't speak the same language.
The Jaycar one, I think, works well on AC signals and not on PWM signals. If you have a need to convert a PWM, the smart approach these days would be to program an arduino to take in, modify and spit back out. Would only take a few dozen lines of code and possibly a variable resistor to allow you to adjust the effect without reprogramming.
  • Like 1
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
