Ahh sh*t rounded oil return help
the aluminium adapter that goes into the block is rounded and it’s fu**ing tight...
basically I was removing my an 10 oil drain/return for a bigger ID metal one as the holset was smoking.
ive tried molgrips but it literally doesn’t budge only rounds it more. it’s a 28mm so the off the shelf rounded nut socket thingys won’t fit. Any ideas ? I might try file it a little and hammer a 27mm socket onto it.
Edited by r34.rory
If you can find a couple of nuts that will fit on wind them both on. hold the bottom one and tighten the top one - really tight . Then put a spanner on the bottom one and undo...supposing that you have the room to do this.
  • Like 1
a bit of heat always helps, ally fittings can seize in a cast block unfortunately.
Given that its already f**ked id take to it with a hammer and chisel after a bit of heat to try and get it started. Once it goes should be easy enough to get on.
sounds funny but another option might be those plumbers pipe wrenches as its a pretty big fitting if you have space
Is this in a GTR?  If yes then it makes it a dog of a job as the front drive shafts are right in the way and impossible to do anything from underneath.  If not you should be able to get to it from underneath with as Duncan mentions a pipe wrench or something.  If it's totally rounded off try grinding two flat faces each side of the fitting (in the right spot to be able to get a spanner or shifter straight onto it) and see if that works.  Having 2 wider faces might give you a bit more purchase on it.  Could be a motor out job if you haven't got much room to play with under there.....
21 minutes ago, Rusty Nuts said:
Mate, I found that classic piece of British engineering laying in a paddock on the old mans farm. This is it after being freed up and oiled.
Our dam has been equally kind over the years as the drought has gone on. Got a hilux alternator from it the other week
  • Haha 2
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
