I Have an R34 GT N/A and I rebuilt it and converted the working engine With:
-CP Neo forged pistons
-Manley Rods
-Garret Gt3071r DDB Turbo
-Series 2 stock fuel rail and injectors
-Series 2 exhaust manifold
-SplitFire Neo coils
- New iridium NGK Plugs
-255 Walbro Fuel Pump
-Freddy Forward Facing intake
-Stock GTT R34 NEO Turbo ECU
-Many Many more....
After my conversion build with all new parts, i primed it and started on the first Crank.
CURRENT STATUS:
-Crank and starts instantly every single time and runs only when applying throttle
THE PROBLEMS
- Sounds great however it if you do not apply throttle and leave her idle, she is struggle to breathe and stutters and will die
- Jumps up and down the rev range by her self
- Cannot find a decent idle and when she does its not for long
- After reeving and she goes back down she dies
- Sometimes when reeving she break up on her own
SOLUTIONS/TROUBLE SHOOTING
- TPS sensor needed to be adjusted to get the right Ohms. After we fixed it it seemed to be more consistent when reeving and staying and holding at an RPM's and slightly better idling.
- Idle air Controller,  adjusted the screw and tried over 10 positions, although it actually really helped idling it still did not cure the dying at idle problem and finding a good idle problem.
NEXT STEP (tomorrow)
Take a look at the base/ignition timing with a timing light to the notches on the crank pulley and adjust it with the CAS sensor?
DOES ANYONE HAVE EXPERIENCE WITH IGNITION TIMING? HOW DO I DO IT PROPERLY? WHAT DO THE NOTCHES INDICATE? WHAT NOTCH DO I WANT TO BE AT?
ANY ADVICE IS GREATLY APPRECIATED
There is a good guide on timing in this thread. BUT use the no 1 spark lead not the loop at the back of the engine.
You will need a Nistune chip in your ecu, a better AFM and probably better injectors.
I take it you have properly cleaned your idle valve and have your BOV plumbed back and not venting to atmosphere.
  • Like 1
UPDATE: for anyone who may be interested and can learn from this in the future....
It was MY Idle Air controller unit and it also being not having the vacuum lines  plumbed correctly.
After this a few test drives, adjusting the idle air screw and letting the ECU learn, i am almost completely sorted
  • Like 1
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
