Alternator isn’t charging and cluster isn’t working. The far right relay was not working and I jumped it and cluster worker. Alternator still not charging. Black wire behind middle relay in photo is broken. Can anyone tell me what that wire and those relays are for? Can’t find anything. Car does not crank now after small black wire breaking.
This sounds like a serious failure. Some 90s Nissans have main fuses, others have fusable link (rated lengths of wire). This and the grounding (as mentioned above) is where i would start.
Some cars require a particular RPM to be reached before they switch the alternator circuit.
If none of this is helpful, i'm afraid you'll need a wiring diagram and to go hunting... ?
Somewhere on here there is a printout you can use for an R33 for the fuse box...laminate it and then glue to the inside of your cover.
I'm sure there would also be one for an R32...you just need to search.
And stop making multiple threads for the same issue, it is not the way to get answers!!!
