Hi,
just bought a R33 GTST with 150000 km / 93000 miles. Engine fells strong, pulls nice and smooth. Nothing to complain
But today I did a compression test. Engine was warm, throttle full open, oil is at max.
Results: All six cylinders 8 Bar / 116 psi.
Is it still ok for a 24 year old RB25? Or should I expect it to fail anytime soon?
Regards
Generally, because test conditions and procedures vary, you'd be looking for consistency in the result (which you do have) more than the specific numbers.
Apart from actual engine problems, bigger cams can lead to lower results, but so can incorrectly calibrated gauge, poor battery charge, test technique etc etc
It is higher klm so you should expect some ring wear by now, I'd keep an eye out for white smoke and oil consumption between oil changes, that should give you a good indication if they are worn.  In any case, those results are no sign you are about to have a sudden failure. Maybe just start saving for a rebuild (cost will vary based on how much you do at the same time)
I've seen some big variances in gauges, specially with so many "quality" ones getting around. I've had the same motor on the same day read 125avg on one gauge and 165avg on another.   Knowing your gauge and then looking for consistency is the key. It's not common that all cylinders read low.
There are differences between compression testers. I've used two testers on my built engine and they varied 50psi in reading. As long as the compression between cylinders are even then the engine is likely to be good.
  • Like 1
13 hours ago, SiR_RB said:
Maybe has a thicker metal head gasket ?
adjustabke cam gears or camshafts ?
results are consistent if you wish use another gauge and try again
Engine looks stocks except for R32 GTR wastegate spring(boost ~ 0,5 - 0,7bar)
I will try to do compression test with another gauge. Will report back when I get it done.
Good tune, good parts, big boost, rip skids.
I had a 300 000km (maybe 400 000km, Edward Lees SE Odo windback) motor making 372kW and abused so bad on the track, skid pans, Mexico before it exploded 1.5 years later.
Huh? how do you know it has R32 GT-R wastegate springs?
Engine might have been rebuilt with thicker headgasket. Maybe it has different pistons/cams/etc. Or maybe gauge isn't accurate *shrugs*
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
