Ok shitty electric problem, so I turn the ignition on and the battery light does not turn on. All the other dash lights do, I have checked the bulb and continuity from the red/white wire at the alternator plug to the ecu pin and there is no break in the circuit. The alternator is not charging, I have tried 3 different alternators all having the same issue. I have checked everything at the alternator there is no voltage loss or any reason it shouldn’t charge I am stumped. Any ideas?
sorry for a sort of double post
https://www.sau.com.au/forums/topic/479084-battery-light-issue/
Get the R32 GTR workshop/service manual from one of the million easily findable places where it can be downloaded and use the very extensive and correct wire by wire wiring diagrams. These show you what is connected to what. For the why (of things being connected) you may need to do some "how things work" research into how alternators work. Once the wiring makes sense, you can troubleshoot it.
  • 3 months later...
