thanks for the response, thought it might be different for the stagea.
i just got a response from matt at nistune, ecu boost sensor is pin 47 ( at least on the r34 ), had a look on my S1 C34 stagea ecu loom pinout and there is no wire so confirmed s1 stagea didnt come with boost sensor ( s1 c34 runs s2 r33 engine with r34 type ecu harness).
does anyone with a c34 know what that plug is for?
i will most likely unpin it from ecu harness and pin it into pin47 for boost sensor on my neo nistune setup for s1 stagea
Looks like the wire to the stock boost solenoid. Are you still running the stock solenoid or do you have a boost T or suchlike? Could well be pin 104.
  • Like 1
running 15psi at aftermarket wastgate
oh right stock boost solenoid, used to limited boost until up in the rev range ( i'm way too comfortable with rb20's, forgot newer rb's run such trickery )
cheers for that
now to see if my new de-pinning tools will work better than my old method of using a sharpened metal nail  :laugh:
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
