Hey guys I hope I'm posting in the right forum.
I have a 2009 skyline v36 370 gt. and it started giving me some problems.
1.Inside the interior started to get hot where the pedals are located.
2. it would make ticking sounds.
3(here is where the problem accelerated im not sure all of this is connected. I was riding on a hill and accelerated then as I accelerated my car could not Drive up the hill my rpms were at about 3-4 regular speed but it couldn't do it.
I parked it pushed in reverse and drive it moved.... but as I drove off it sounded like the engine was working but straining at the same time but I was unable to move regularly.
I left it parked up for about 2 days trying to find a mechanic. Found one he ran a diagnostic test on it. the test code p0734 came up.... He told me it may need fluid, solenoid may need to change and some other details..
But we let the car run at idle to see if any more scans would appear... nothing showed we took it for a drive for about 15 mins, the car seemed fine as if the problem never happened.
\Does anyone know what could be the problem?
https://www.sau.com.au/forums/topic/479105-skyline-transmission-problems/
The code is definitely transmission related but if it seems OK now, perhaps it was a sticky solenoid. Either way, as GTSBoy suggested, take it in to an auto transmission specialist, preferably one who knows these Nissans reasonably well.
I don't know how easy or difficult it is to take out the valve body and check the components within, including solenoids but in light of what you experienced and the nature of the error code, it's definitely worth doing in case the fix is cheaper than a rebuild. Don't let it linger for too long, even if it is seemingly OK again now.
Best advice given I appreciate it. Its just that im located in The Bahamas and finding a good mechanic is really looking for a needle. in a haystack. Everyone is looking out for their pocket so they may tell me anything just to get the job. Ive been doing research about the ATF Fluid and from what I gather only the Nissan metic s fluid is what's best to use. Funny thing is no store on the island has it!
aw man so im ordering a case and parking her up until I can get the fluid and hopefully find a good mechanic in that space of time
Bugger. You've got it pretty tough over there, eh?
Good idea to stay off the road until you can get it looked at properly though. You don't want to strip more life off the transmission than it may already have. Good luck mate.
  • Like 1
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
