Nismo 555cc RB26 GTR low impedance, top feed injectors and GTR injector pack. Good upgrade for GTR or wire in the injector pack and they'll fit your RB20DET. Excellent condition. $450 ono. Pick up Modbury area or can post.
https://www.sau.com.au/forums/topic/479123-parts/
Gktech 'dog bones' with bolts/washers to fit 324mm R33 GTR rotors onto the front of your : R32 gtst, S14, S15, Z32 and A31 Cefiro. Rotors included are quality DBA 4000 series that were recently machined. To fit this kit you'll need at least 17" rims. $300 ono. Pick up Modbury area or will post.
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7918852
CA/SR S13 gearbox crossmember type 'B'. This is needed when converting R32 four door or C33 Laurel to manual and might work on others. $20. Pick up Modbury area or can post.
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7919314
Bendix ultimate rear brake pads DB1220 ULT to suit R32,R33,R34 Gtst & Gtr and 300ZX. Quality performance brake pads that originally cost me $140, asking $60. Pick up Modbury area or can post.
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7919315
QFM Performance front and rear brake pads DB1170 & DB1220 to suit R32,R33,R34 Gtst & Gtr and 300ZX. Quality, metallic brake pads that originally cost me $230, asking $120. These organic metallic pads are well know for their all round performance, they have excellent stopping power on the track, whilst still being good on the everyday drive by warming up quickly on the street, and they last. Pick up Modbury area or can post.
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7919316
Whiteline adjustable rear upper control arm bushes, camber adjustable by +/- 0.75 degrees. Will fit: 180sx, 200sx, 240sx, Cefiro A31, S13,14,15, R32,33,34 GTST & GTR. $75. Pick up Modbury area or can post.
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7919318
SOLD
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7920316
SOLD
https://www.sau.com.au/forums/topic/479123-parts/#findComment-7920317
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
