On 08/11/2019 at 2:55 PM, partyboy73 said:
OEM oil filter to suit RB20DET, RB25DET, RB26DET, CA18DET and VG30DETT (ryco # Z145A), $15. Pick up Modbury area or can post.
SOLD
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7920318
On 31/10/2019 at 3:17 PM, partyboy73 said:
Nismo 555cc RB26 GTR low impedance, top feed injectors and GTR injector pack. Good upgrade for GTR or wire in the injector pack and they'll fit your RB20DET. Excellent condition. $450 ono. Pick up Modbury area or can post.
INJECTORS SOLD
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7920620
On 31/10/2019 at 3:32 PM, partyboy73 said:
Gktech 'dog bones' with bolts/washers to fit 324mm R33 GTR rotors onto the front of your : R32 gtst, S14, S15, Z32 and A31 Cefiro. Rotors included are quality DBA 4000 series that were recently machined. To fit this kit you'll need at least 17" rims. $300 ono. Pick up Modbury area or will post.
DOG BONES AND ROTORS SOLD
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7920621
On 08/11/2019 at 2:41 PM, partyboy73 said:
CA/SR S13 gearbox crossmember type 'B'. This is needed when converting R32 four door or C33 Laurel to manual and might work on others. $20. Pick up Modbury area or can post.
CROSSMEMBER SOLD
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7920623
On 08/11/2019 at 2:51 PM, partyboy73 said:
QFM Performance front and rear brake pads DB1170 & DB1220 to suit R32,R33,R34 Gtst & Gtr and 300ZX. Quality, metallic brake pads that originally cost me $230, asking $120. These organic metallic pads are well know for their all round performance, they have excellent stopping power on the track, whilst still being good on the everyday drive by warming up quickly on the street, and they last. Pick up Modbury area or can post.
QFM PADS SOLD
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7920624
OIL FILTER SOLD
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7920625
  • 1 year later...
Check Your PM Man!
https://www.sau.com.au/forums/topic/479123-parts/page/2/#findComment-7949134
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
