piping install for 600X300X76 cooler
wados
 Share
bracket i made, its bolted on where the horn used to be
http://www.tygarbyte.com/huev/images/inter...racketmount.jpg
I grinded that lump to make the surface flat. and then painted it.
height from the ground.
total days to install all by myself ? 4 dayssssss.............. got freakin sunburnt doing it tooo.
Hopefully i should have it completed tomorrow.
Hi bangahh how did it turn out with the front bar fitted?Can we get a pic...
looks very neat.How much did you pay fro the 180 degree mandrell bend?And have you used the mounts on the bottom on the intercooler to help give it more ridgidity?
  • 3 weeks later...
  • Replies 70
Posted Images
waldo - did you paint the inside of the pipe as well ? I think I might try and paint the inside aswell.
I've seen several so-called heat-proof paints flake away quite easily too, and your cooler piping ends up full of slightly oil residue anyway, so i can only see it worthwhile painting the outside...
RowdyR32's old setup, before he put a RB26 in, looped in front of the radiator but that was the pipe feeding the intercooler NOT returning from it. Sure the intercooler has to sink a bit more heat but a 600x300x76 is pretty huge for a RB20, if you're not going too extreme, and the pipes just before the manifold barely got warm.
  • 9 months later...
  • 1 month later...
  • 8 months later...
Hey guys,
well i posted in this sect originally as r33dan, well my car has come along now heres some pics if my new cooler piping i made yesterday (well tack welded yesterday finishing this week and spraying it)
Edited by sinistagtst
yeh cooler piping should work fine on 32gtst, just a case off looking trial and error with angles etc, remember to measure ten times cut/weld once. and front bar do a search man theres plenty of threads on it.
 Share
