hey all,
Im going back and forth what to do.
Im building a r32 gtst at the mo. the engine is tired tired, blowing smoke etc. I was going to drop a rb25 i had laying around but i cant be assed going through regency and dealing with all that rubbish now.
Id like to keep under the hood as standard as possible. Was going to forge it, but is there any worth while strocker kits? Is it even worth the time and effort? especially seeing as im going to keep a low mounted turbo, internally gated.
I keep going back and forth between just rebuilding, adding a cam and smaller responsive turbo and leave it at that.
Any ideas?
https://www.sau.com.au/forums/topic/479199-rb20/
Well, the RB24 was born from jamming the 25 crank in and boring it out, wasn't it? Or was that RB23 and you get 24 from a 26 crank? Either way, you could enbiggen it reasonably easily.
'Twere me though, having to live with an RB20 again, I'd strap a supercharger onto it down low on the exhaust side and twincharge the f**ker. Make an effective 3L out of the 20+blower and then turbo for that.
You know you want to.
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919893
Why bother with Regency, stick the 25 in. No half arsed copper could tell the difference by looking in the bay, plenty of plods have looked in my bay and none have said "Hey thats a 3.0litre in there". Just need plenty of thick paint over the engine number.
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919899
as said rb25 with rb20 covers on it no one would know
Anyway i had a full forged etc rb22 in my drift car for years - in terms of better than rb20 yes but marginally more came from the boost I was able to put in it and because I was drifting so always in high revs.... eventually swapped to stock rb25 - which was just way better
ie: either mild rb20 or rb25 too much $ for not enough return for rb20 stroker
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919901
Pretty sure no one, well no one that matters, cares about cam covers.
When I have been pulled over it was always only the rego plate check, and obvious defectable modifications, the only time the engine/body number and tags were wanted was when I had my 25/30 engineered and added to the rego,  1 Hwy patrol officer who was very thorough (he seemed overly angry at the world) and once at a pop up RTA (RMS) inspection station on the Foreshore in Botany.
This all counts for nothing if your involved in a big crash and/or insurance companies get involved.
If a insurance company can prove you car is not roadworthy they pay nothing, having a different engine than what is on the rego papers instantly makes the car unroadworthy.
It would negate the green slip 3rd party as well.
Food for thought for a worse case senario situation.
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919906
I always hear that kind of statement but never directly from anyone that it has happened to
Has it ever actually happened?
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919907
The actual truth is that the "illegal" / "unroadworthy" / "unapproved" modification has to contribute to the incident that causes the claim for the company to deny the claim. If the insurance company cannot show that the mod was at least partially responsible for the claim, they cannot deny the claim.
That's a pretty low bar though, and one would have to be pretty wary about things that would be very easy for them to make a statement that you couldn't refute. Wheel spacers would be an easy one for them, for example. An illegal, much bigger than permitted, non-engineered engine swap would be something that they would have to have seen a lot of times before and be well prepared with statements about how that could cause just about any incident.
I wouldn't ever bet against a motivated insurance company.
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919909
In my insurance agreement it states that my insurance can be void if I don't inform the insurer of any changes.
Not my insurance company, but.....
3. Modifying your car (without telling your insurer)
https://www.finder.com.au/car-insurance-exclusions
My suggestion is to read your agreement, in the end expect the insurance company to come at you pistols blazing.
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919917
If you advise your insurance company of a modification and that modification is not actually approved by the vehicle standards department, they can still crap on your claim. If you read these clauses in most (if not all) insurance documentation you will see weasel words hidden in there about how the mods have to actually be legal.
If I told my insurance company that I'd put a forward facing hornet scoop on my car, over the top of a tunnel rammed carb fed 600 cu.in V8, they'd say, "Thanks for the advice". It would not be any good if I had an accident where I scalped a pedestrian when the throttle cable jammed open in a carpark burnout and put the car into the crowd though. They would be well within their rights to point to the pedestrian maimer on the bonnet covering the non-emissions compliant, 3x too large engine and laugh at me.
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919919
Yeap, this is why I paid a kidney to insure my "engineered" shit box R33 Skyline with comprehensive, and ended up swapping to third party fire and theft.
I am currently working on getting my 86 engineered, doing so will be fine for my rego and green slip, BUT, the cost of comprehensive insurance for it will be as high as Amy Winehouse on a bender.
That's if I can find a insurer that will cover it.
Meh, third party fire & theft may be an cheaper option or third party property cover if all else fails.
The only way to be safe insurance wise it to get an engineering certificate for all modifications stating the car meets all required guidelines and declare every modification on your insurance agreement.
It's possible to be covered and not get rogered, but you need to follow the bouncing ball then stick your hand deep into your pocket.
Or, risk it for the biscuit......
Mmmmmmm, biscuits
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919921
1 hour ago, Adz2332 said:
or more budget friendly option lol
I thought it was way cool, till I looked at the price. Well, if you had a HR31 GTS-R that didn't have one, and it was mint, then yeah, I guess, maybe....
$5k, wow
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919964
I  got my car certified for all the mods. Yes it cost $600 but that's peanuts compared to the $$$ I poured in to the mods. In NZ all the mods that are allowable if certed are covered by regs so you make sure your car can be approved before you get an inspection. If in doubt or you don't have access to such regs talk to an inspector before you start to make sure its going to be able to be certed.
  • Thanks 1
https://www.sau.com.au/forums/topic/479199-rb20/#findComment-7919968
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
