Hi everyone
I'm a first time poster to this community so please forgive me if I have made mistakes.
I own a 2003 GT8 Skyline which has the 8 speed CVT transmission and a vq35de engine.
This morning I encountered a problem with the car where it won't start.
The engine will crank over but not start. I had tried 6 times before the car eventually started. When it started, the instrument cluster had the abs, slip, and the vds lights all on. Also the tachometer was not working and the gear indicator under the tacho was blank. I was scared to drive the car so I turned it off. When I tried again, the engine would just crank over but not start. After 45 minutes I tried again, this time it fired up on the fourth try and I managed I move the car from the basement parking (I live in an apartment). Again the abs, slip and vds light where on and the tacho wasn't working and the gear selector didn't show which gear I was in.
Racv turned up and they couldn't work out what was wrong. The technician couldn't get any fault codes as his OBD2 reader didn't work when connected to the my car.
Then about another 2 hours later I tried to start the car, which it did (first try this time) but all abs, vds and slip lights were on with the tacho not working and the gear indicator being blank.
Does anyone have an idea what could be wrong?
I have read somewhere it my be the cam sensor.
Please help as I would like some know how about the above situation.
https://www.sau.com.au/forums/topic/479231-2003-gt8-not-starting/
If it will drive, drive it to a mechanic and pay them to fix it. If it won't drive, get it towed.
It won't be your cam sensor. You have a blown fuse or a broken wire or something has burnt up or somesuch other random electrical failure that can only be diagnosed by poring over the car with a torch, a testlight or multimeter and a working diagnostic computer.
Edited by GTSBoy
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
