Locations: Qld, Redlands, will post all except exhaust.
Postage will be pre-paid satchels with tracking, so whatever they cost.
HKS 3" exhaust with heat wrapped Dump. ***** Pickup only ******
NOTE: Has a tiny pin hole in the dump and a crack as pictured, all fixable.
$700
IMG-20191123-152318.jpgIMG-20191123-152327.jpgIMG-20191123-152338.jpgIMG-20191123-152406.jpgIMG-20191123-152455.jpgIMG-20191123-152512.jpgIMG-20191123-152828.jpgIMG-20191030-175939.jpg
HKS OB-Link for NM35
The only one that reads our car and can display on your Android stereo showing sensors and fault codes instantly.
$220
Innovate 3918 Wideband AFR gauge kit + interior bits pictured if you want.
Genuinely done less than 300km.
$200 bargain!
IMG-20191123-152034.jpg][/url]IMG-20191123-104217.jpg
ITSROM Stage 1 ECU
Setup for: 3" Exhaust, FMIC, 14PSI, Intake.
Screenshots showing ECU scan with no faults before removal.
$370
Stainless steel intake, you will need some new silicone as pictured.
$250
Factory genuine O2 sensor also genuinely done <300km as new.
$40
  • 1 month later...
  • 3 months later...
  • 4 weeks later...
So do you have the exhaust and intake?
Would you be willing to seperate the dump pipe??
If i prepaid the shipping could you do shipping?
  • 1 month later...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
