Hi all,
What’s the difference between the Neo and Non-Neo Apexi Power FC for the RB25DET?
They don’t come up second hand for the RB25DET very often in the UK, Loads for the RB26DET.
a NEO RB25DET one has popped up on eBay and I wondered if it can be fitted and/or modified for my R33 s2?
cheers,
Ollie
Nope. Won't work. Neo has at least one sensor that the vanilla 25 doesn't.
You could f**k about and make it work, but I can't see the point in f**king about for a f**king PowerFC. There are much better ECUs available now. You would be (much) better off putting a Nistune board into an RB20 ECU than using a PowerFC. Or a proper standalone.
The ECU connector is totally different (2 row vs 3 row), you need the non-neo one to match your car.
They should come up all the time, r33 rb25 Power FC is reasonably common, r34 neo rb25 less so
