Hello every one
I have a skyline R33 ,1993 RB 25 DET .
I'm having a problem with my battery it's run down every time the car is parked I check the alternator ,I check the alarm I check couple other stuff the car won't start if you jump start it it will  works fine ,but when I park the car for a couple of days the battery is dead ..
Any one can across an issue like this
Edited by Rawad
https://www.sau.com.au/forums/topic/479249-battery-issue/
9 minutes ago, GTSBoy said:
So you know what the problem is. Go fix it. How the hell do you expect us to know what it is.
Dude I try every thing I can think off ...I disconnect the alternator,I disconnect the horn the ECU the fuses in the engine bay ,the alarm ..each by it self ..and none of this was faulty ..
I can't think of something else ....
U don't need to get angry ..if the post troubling you ,just ignore it
https://www.sau.com.au/forums/topic/479249-battery-issue/#findComment-7920332
It's the other thing then.. Next to the first bit.
Seriously this pretty much can't be diagnosed online. Are you using a multimeter for testing current draw on the parts of the circuit or just randomly disconnecting stuff?
https://www.sau.com.au/forums/topic/479249-battery-issue/#findComment-7920334
Not really Randomly ,I'm disconnecting them in sequence..I give the car couple days after each part or set of fuses to see if the battery still draining...
https://www.sau.com.au/forums/topic/479249-battery-issue/#findComment-7920343
I recently went through this. Honestly given how this can only really occur with non-standard stuff its where you'd begin. It's almost always a device is on (when the car is off) and its draining power that way.
Common suspects, Audio systems, reverse cameras, ODB2 connectors, Dashcams, Alternator Diodes failing so alternator is always 'excited'
In my case it was the alternator being wired to the horn fuse, so it was always excited. As this was an engine conversion (I didnt do the wiring) this is in the category of "Stuff that changed".
https://www.sau.com.au/forums/topic/479249-battery-issue/#findComment-7920418
Have you taken the new battery to where you purchased it to see if there is potentially a dead cell in the battery?  This can happen, I . bought a battery and 6 months later, ended up having a dead cell.  It was still under warranty (as yours should).  Have them test it if you don't own a tester and should easily rule the battery being an issue.  Much easier to start there vs. digging around and ripping things apart.  Just my .02 cents.
https://www.sau.com.au/forums/topic/479249-battery-issue/#findComment-7920936
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
