Sticky and good in the wet, tricky combo.
You could try Bridgestone Potenza RE003 225/50 16, they are a compromise, OK in the dry, OK in the wet, but pretty cheap.
If you can sacrifice wet grip Hankook RS4 225/50 16 are great in the dry, but average in the wet, cheap tyre as well.
I did replace my RS4's with RE003, but I'm RWD and the Mrs and kids also drive the car, if it was just me I would still be running RS4's.
Just drive to the conditions and the RS4's would be my pick.
I wouldn't complain about RS4 grip in the wet. I think they stick fine in the wet, so long as they have some heat in them.
Same with any semi semi really.
My other vote is for AD08R. They are still the best street tyre I've had in the last quite a few years. The RS4s are going to last longer, and they're nearly as grippy. The only problem is the Yokos are usually a bit dear.
My recommendations to people are:
Cheap but competant: RE 003s
Expensive but performance orientated: Advan AD08s.
I run RE003s on our family wagons (more than up to that task) and AD08Rs on my GTR and have been pleasantly surprised by their grip. In particular in the wet they hung on way past what I thought they would be capable of.
57 minutes ago, niZmO_Man said:
I wouldn't run RS4 or AD08 unless you're tracking the car. Take a step down to 'ultra high performance' tyres like RE050, S001, Advan Sport V105, Pilot Sport 4, Eagle F1, DZ102, FK453, and my favourite, Ventus K120.
I wouldn't call the RS4 or a AD08 a "track tyre" with a 200 tread wear ratings.
I would concider them an excellent choice for a R32 running 225, I would hazard to guess the car is not a daily, and driving around whilst it is raining would not be a big enough reason to justify sacrificing grip on the off chance you get caught out in the rain.
Performance tyre, yeap, most certainly, but there is no way in hell I would put any "all season" tyre on anything other than the Mrs car, or a taxi.
Hell, I hate having RE003's on my 86, the drop in grip from the old RS4's to them was quite, um......alot, but the RE003 are better in the wet, and with the Mrs and kids driving the car I wanted a bit more fudge factor.
In saying this I was quite happy driving the car in the rain/storms/winter on the RS4, they were great on the 33, MX5 and 86.
They were OK on the track for a lap or 4 in the 1540kg 33, but anymore and they tended to get slidey, they did last longer on the MX5 though, but that only weighed about 1000kg, and only had about 5hp.
But, yeah, meh, opinions and stuff, plus my driving style could be better, and the setup on the 33 could have been better.
I really need another set of rims to put some RS4's on.
I can see it now.
Mrs: can I take your car
Me: sure, you just need to swap the rims honey
Mrs: what????
Me: I'm swapping them now honey
Kids: hahahalolololhaha, sucker......
Me: sigh
Based on my experience with my RS-3, I'd recommend RS-4 easily unless you're after wet weather grip more than dry. I'm eyeing RS-4s next year after clutch change.
The RS-3 were excellent in the wet for the tread pattern, surprised me with the amount of water it can displace. Oh and my friend who daily'd an MY05 STi changed to AD08R and said they were great in the wet, better than OEM RE760 or whatever, but don't last long for obvious reasons.
So it really depends on the OP's needs. How much driving (km's), how much of that in wet (not that much IMO).
The best "street" tyre (UHP) I've driven on were RE050, Advan V105 and FK452.
  • 4 months later...
  • 4 months later...
Anyone running bigger than a 225 on stock 32 GTR wheel?
Was hoping to run the Nitto NT01 245 but can't find any stock anywhere in the country nowadays...
Anyone got any other suggestions/recommendations? Don't want to run MT's either...
A 235 would be a good size if there was an appropriate profile to give the right diameter, but there really isn't. If you're willing to put up with a change in diameter, you could do that. 245 is a little too wide for an 8" rim. Somewhat baggy, especially on a 16, where you end with a lot of sidewall height bagging out.
  • Like 1
https://www.tirerack.com/content/tirerack/desktop/en/homepage.html?to_desktop=true
I have imported from this place with good success.
Especially when it starts to get cold in the states and they put all the track and summer tyres on special.
  • Like 1
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
