First item
HKS Step 2 Cams (IN and EX) for RB26
$800.00
Used, but in good condition. Came from an R33 GT-R
PRICE NEGOTIABLE
Cams Specs: Intake cam: 264 10.2mm Exhaust cam: 272 10.0mm
Gives a nice lumpy sound, if that's what your're into. Located in Casey area, Victoria.
PICK-UP ONLY (willing to meet elsewhere, if i'm too far)
Second item
Custom 2.9L Stroker Kit for RB26 (pistons, rods, and crank)
$3000.00
Not sure what it's truly worth, so PRICE NEGOTIABLE!
Located in Casey area of VIC.
For now, not willing to separate the parts as the pistons and crank only work for this kit.
Kit was developed in SA by a company named Rhemac.
Ideally this kit would suit someone chasing cheap easy power, using a virgin bore or brand new RB26 block (due to piston size).
Has cracked 481kw on a hub dyno (HKS 2530s, e85, Vipec V88) and 435kw on roller dyno (same specs). Final tune was 426kw by RacePace Motorsport.
Specs:
Pistons: 86mm CP forged pistons and rings. Custom design. Pistons do have markings on the sides, however still usable. Recommend them getting re-coated. Custom in terms of shortening comp height (distance from gudgeon centre line to crown of the piston).
Rods: Eagle h-beam rods, standard RB26 size. Only part in this kit that can be used standalone. Comes with ARP 2000 rod bolts.
Crank: Custom made RB30 crank (yes that's right VL crank), nitrided and balanced with collar fitted (what my research is telling me). Basically the kit creator has shaved down the counter weights so it all just fits in the RB26 cradle/block. In saying that, the crank still brushes on the piston oil squirters, though the kit was inside my car and was used for over 40,000KMs was working well enough.
I can discuss the reason why I decided to change my engine from this privately, as it is quiet a long story. The kit works and gives a lot of torque. No it's not the most efficient or reliable but if you're chasing an easy means for power (racecar anyone?) this kit is great for that. I don't claim to know the ins and outs of this kit. I'm simply going off the paperwork I received from the previous owner, as well as forum posts from the kits creator. If genuinely interested, I can get you in touch with my mechanic who can definitely do a better job at explaining the details, as they took my old engine apart with this kit in it.
PICK UP ONLY
IMG_20191129_234637.thumb.jpg.3f7b12c141def2a75077f2c26a6e3de5.jpgIMG_20191129_234722.thumb.jpg.53ea9a42ba5483fdd4c579799816bb00.jpgIMG_20191129_234732.thumb.jpg.f6fbe06a1bb01ba1580abf098abe16a9.jpg
IMG_20191130_122743edit.thumb.jpg.2154b8383169fc049ea0d1cc3ef2f2ed.jpgIMG_20191130_122746edit.thumb.jpg.0a5b8ab1729dfe0dc710bc0faf19f3fa.jpg
  • 4 weeks later...
  • 2 months later...
  • 2 months later...
  • 1 year later...
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
