7 hours ago, KiwiRS4T said:
So are you back on two feet?
I'we been walkin 1,5 weeks now more or less (mostly less) well. Still waitin surgery and my knee hurts and running and jumping is off the limists.
1 hour ago, robbo_rb180 said:
Great work so far. Like the diy fibreglass stuff.
what sort of circuit stuff do you do? Time attack, sports sedan?
Time attack it is. Modified class in finland. Car must be raoad legal or close to that. 8cm ground clearance, weld in roll cage, racing seats, 6-point harness, h-pattern gearbox, road legal tires etc. Some aero mods are ok. No flat floor.
  • Like 1
Many irons in fire at same time again ?
Door cards are almost done. Made them from two parts. Put then together with glue and rivets and then teo layers glass fiber on top. Now just trim and smooth them before painting.
Did hole for naca duckt for fuel cooler.
And also bigger switch panel from carbon.
Comettic gaskets for engine arrived yesterday. Now I can took head and block to machining shop.
Edited by PranK
Fixing thumbs
  • Like 1
 Door cards are finally ready to bolt on ? Not the best result, but still happy. Now thinking that I should do them different way from the beginning, but not this time. Maybe if things start to bother me too much.
Removed that duck tail spoiler, what was for stock boot lid and didn't fit at all. Thinking different style and maybe better spoiler there.
Edited by PranK
Fixing thumbs
  • 3 weeks later...
Little break from fiber glass s*hit and welkome elektrick s*hit ?
Light and wiper controls are long gone from original places.
Ewerything is now in centre consol.
Only horn and side indicator swtches are behind the wheel.
These are possible to add there by using original spiral. There is 4 places for wires and 1 was allready for horn and 2 is easy to take in use.
Started to do wiring last time. Main power cable is in it's place now. I used green garden hose for extra cover. That green garden hose is so ungly that I'm going to cover that with light nylon sleeve.
Also that wiring harnes from dash to boot is almost done. It would be done, but I forgot 2 cables from there (sometimes dpin things too fast and forget something)? Used old cables as long as possible. Took everything what I don't need out and add some new cables. There is only rear lights and original fuel pump cables left from old harness. And new cables for fog light, electronic main power switch conroll, second fuel pump and fuel cooler fan.
And I had also my 29th birthday here a week ago. And my wife had bought Cube premium shifter as birthday present ? Had to bolt it on right away and it feels awesome.
Edited by PranK
Fixing thumbs
  • 4 weeks later...
At this week I tes fitted radiator, oil cooler and all body parts what I have for this. I'll  do new front bumper and rear diffuser at some point. Front fenders and lights need's some adjustment to fit properly.
Edited by PranK
Fixing thumbs
  • Like 1
I foun company from here Finland who can do spiral cable at steering column for me. So I did new switch panel behind the wheel. There is now switches for high beams and wind skreen washer also. And I can get rid of that terrible original spiral box.
Also did door harnesses ready. Only power window cdles left in doors. Also shortened those cables to suit better for my application.
Lowered front suspension, adjusted camper and bolt front stapilizer on. Also fitted horns behind right head light.
Edited by PranK
Fixing thumbs
  • Like 1
  • 2 months later...
No real progress here. Had been spending some family time.
New race car driver?
New n1 oil pump waiting spline drive gears.
And collecting fuel parts also.
Engine is ready from machinimg shop. Need to get them collected when I have time to get them.
Edited by PranK
thumbs
  • Like 2
Found out that my glass fiber door cards didn't fit too good and they are f*cking heavy too. So I dumped them away and made aluminium ones. I'll fit tham in with pop rivets and will just hammer them to dit around roolcage. (No photo today)
And also used some time outside and made air vent on the bonnet. Angle grinder was allready warm so I took few kilos off the bonnet too. Painted edges to keep rust off. Aaaand also found some old paints and used tose for doing some art.
Edited by PranK
thumbs
  • Like 1
  • 4 weeks later...
Had garage morning yesterday.
Installed redline heavy shock prof oil in diff.
And also driver side door panel is almost ready now.
Also got engine and manifold from machining shop. And engine is waiting internals.
Edited by PranK
Ficing thumbs
  • Like 1
  • 4 weeks later...
Finished door cards. I felt my self stupid with window electricks. I had issues with passenger side power window. I took door card off and there was nothing wrong. Another try and everything works great. I think only issue was that child lock button at drivers window switch. It was at wrong position...
Taped driver side floor with some anti slip tape.
Did adjustable suport rods for head lights.
Picked up valve covers and breather can from welder. Started to grind old paint of them.
And last. Who else hates mice? I do..
Edited by PranK
Fixing thumbs
  • 2 months later...
Painted valve covers, breather tank and thermostat cover yellow 2 months ago...
And today I was adding few stickers on..
And bolted new yellow door handles 😂
And also got something real done too. Bolted rain/fog light on the rear bumper. Did wiring for it and finished also wirin harnes for rear lights. And test fitted new spoiler. Only need to figure out how I do wing maunts. I need to get boot open easily. It is light fiber glass lid so it can be lifted off easily. But it won't hold that wing on top. Any good ideas for that wing?
Edited by PranK
Fixing thumbs
Some good news here! I'll get new garage! And new home. We are moving at april. I'll add some picks when I get keys to new home. Now I have to drive 40km to garage and after we had moved it is only 10meters from the hause.
  • Like 2
Ok dudes! NEED YOUR HELP HERE!!!
What are these for? Im doing new wiring to the car and I need to know are these important for power steering or are they only for hicas? And if I need them how I get them in work?
Edited by PranK
Fixing thumbs
Lets add some random picks off what I had done lately.
Steering wheel wiring..
Main power cutt off at outside off the car...
And random rear suspension photo...
Edited by PranK
Fixing thumbs
  • 2 months later...
Ok! Car has moved in own garage.
I'm goin bit different with body kit. Bought gtr style rear quarters. And need to make them bit wider. Not much only 1-2cm.
Bolted gear box in jus for saving some room in garage.
QUESTON!!!...
And one queston for those guys who are drivin their r33's at track. How to set up wheel alignment???
Edited by PranK
Fixing thumbs
  • 2 months later...
Left side rear quarter is almost ready for fibers. I'll do those fiber parts without molds. Only laminating on top off that foam and then cutting off foams and sheet metall from under side. (Saves time and money and timeattack car does not need new body parts after every race). I'm not sure yet if I'll use carbon or glass. IMG_20210623_172708.thumb.jpg.570b3c14be6d6de693b4223d2dfb4e7b.jpgIMG_20210623_175224.thumb.jpg.36c66ee8a8aa1915daa9267ec2494d20.jpgIMG_20210623_175240.thumb.jpg.11ed7a3855e7af973648ca97a615499a.jpgIMG_20210623_175300.thumb.jpg.82886ffa2ba395755715d6e8a2ccc234.jpg
I'm also making smoothing for bonnet went edges.IMG_20210623_164354.thumb.jpg.45f07f791c6dcabc7af6b92db086ad45.jpgIMG_20210623_164333.thumb.jpg.3444f6bbddf29944ffb93aa56bbcc13f.jpg
And new mirrors are bolted on. They are at different places becouse that way I get better wision from them. If passenger side would be at original place it would be behind of roll cage tube.
IMG_20210611_202828.thumb.jpg.fe11de0d80a01b1c3dd7c066c65a4c83.jpgIMG_20210611_202801.thumb.jpg.e2f31085b1571f6ce124a9fe8e7b6af2.jpg
Edited by nuut3ro
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
