After nearly 2 years, I finally got my car “running”. January 2018 I blew my gearbox and didn’t bother getting it replaced because I went overseas for over a year and I just come back last July. So a couple of weeks ago I got my car back from the mechanic.
i got the clutch and gearbox replaced. It’s a R34 GTT and I got the pull type gearbox and a brand new exedy heavy duty clutch. I had also got a few things done in the engine bay such as re sealing the rocker\valve cover and changing a couple of turbo gaskets and IACV gasket.
The first problem is when the clutch pedal is pressed down, it sometimes makes this loud winding/grinding noise. It only makes the sound when I’m stationary. So I put it in gear and as the pedal is pressed down, a loud noise comes from the transmission. When I take it out of gear and put it back to neutral, the sound goes away. It doesn’t do this all the time, but I realised when I cold start the car it does it a lot. After driving for ten mins or so it seems to go away (can’t say for sure though didn’t drive it for more than 30 mins). Like it said, it makes this sound when the clutch pedal is pressed down only and while stationary. I put Lightweight Shockproof oil in the gearbox.
The other problem is the car won’t rev past 3000rpm and around 0.38 bar which is about 5psi ish. The car would normally run 12psi. It’s a r34 rb25det neo op6 stock turbo and I got a power fc tune. I think it’s important to note that the engine got started for the first time in nearly 2 years a couple of weeks back. When in neutral the car would rev past 3000. Also the screen on my power fc hand controller won’t turn on anymore but the buttons still light up. Unplugging and plugging it back in didn’t change anything. I get a feeling the car is in limp mode only because the boost is cutting out around stock factory psi levels but I could be wrong.
Any help would be appreciated I really want to drive my car again!! Thank you
Edited by IM-32-FK
Ok the noise is your release bearing. Should have been replaced when clutch was done. If not, don't use that mechanic again... Unless the sound is there for a little while when you put your foot on the clutch then stops after a bit? If it does that then it's spigot bush in the crank. Again, should always be done during clutch replacement.
With the rev limit, is it revving cleanly or is it stuttering and carrying on to get up to its max revs?
I guess I’ll have to go take it back to him to get it sorted with no extra charge. The winding grinding noise is so loud that I can tell it’s not a normal sound the clutch should make. I didn’t leave it in gear or release the clutch pedal when it makes the sound, I quickly put it in neutral
with the rev limit, it revs out cleaning up until it reaches 3000ish and around 0.38 bar, when won’t rev past that.
Edited by IM-32-FK
Stock wastegate spring pressure is 5 psi. That is very close to 0.38 bar. I would suggest that your boost control solenoid is not functioning. This could be because it is stuck, or because the PowerFC has lost its mind after being left for 2 years (possible, but it really shouldn't happen). Or it might be a plumbing problem.
If the PowerFC has lost its mind, then it could explain everything.
I just had a look at it and took the blitz dual sbc electronic boost controller solenoid off. I blew into the solenoid and I can feel the air escaping from the other end. Also on the solenoid, the plastic nipple was connected to the actuator and the metal nipple is connected to a nipple on the turbo elbow. The hose coming from the intake/bov return is blocked off. There are no T piece connectors or anything like that. Is it set up correctly? I also blew into the vacuum hoses and don’t they feel blocked as I can feel the air escaping from the other end.
also on my previous post I meant to say “ it revs out CLEANLY up until 0.38 bar and 3000ish rpm”
also could the problem be the AFM? it was sitting on my garage shelf for a year and a half a lot of dust could’ve settled in it which could be causing problems. What product do you use to clean AFM’s? Carby cleaner?
Edited by IM-32-FK
No way to tell from that description. Draw a diagram. Clearly label the ports on the solenoid, and mark which are connected when it is unpowered and which are connected when it is powered.
Dust shouldn't affect it. Any dust that can settle should blow off pretty quick. The correct cleaner for AFMs is CO contact cleaner or the dedicated spray stuff for AFMs.
Ok I labeled the image but I don’t understand what you meant when saying powered and unpowered . Also there are no t pieces or any other connectors on the hoses that go anywhere else , they just connected from one end to the other
Edited by IM-32-FK
That does not look to me like the correct solenoid for a Blitz Dual SBC. That looks a lot like the single Blitz solenoid.
"Powered" means "when you put 12V onto the terminals and power it". "Unpowered" means.....you guessed it....
Anyway, you can google up the connection diagrams for these things and see how they are supposed to be plumbed up. Better you doing it than me.
Yeh I looked it up and it is a single blitz solenoid. But it doesn’t matter, it was on the car when I bought it 5 years ago , so I don’t think it’s an issue.
Also I looked at a couple of videos and the connections seem right( one end to turbine housing and the other to the wastegate actuator.)
  • 4 months later...
Anyway, I got the problem fixed a while back and thought I might post the solution here just in case someone runs into the same problem in the future.
- I changed my spark plugs from ngk bcpr7es -8 to ngk bcpr6es -8 . I’m running 12psi boost on rb25det neo so I had the wrong ones in there. (Bcpr7es -8 is used when running from 12-19psi)
- I changed all my coil packs from OEM to spitfire
- I cleaned the inside of the boost solenoid with contact/electrical cleaner. Black soot came out of it.
- I cleaned the inside of the air flow meter (AFM) with contact cleaner as well. There was ALOT of black soot residue in there. I had to use half a can to get all of it out (make sure you wipe the inside and the mesh netting too to get all of it out but don’t touch the sensor thingy in the middle of it with the cloth)
I don’t know which one solved the problem but it was one of them.
  • Like 1
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
