  • Replies 219
Scotsman same here Oil cooler kit without remoter filter, with braided lines (enough to fit on drivers side front bar)
Braided Lines: Retail $650, 15% $555, 20% $520
Do we have enough for 5?
Im interested in picking one of these up also!!!!
One quick question though- I have a tiptronic 34 which has the transmission cooler sitting where I guess the oil cooler would go- does anyone know if this would pose a problem?? Ill be ordering it with a remote for it
Apologies if I should be posting this question somewhere else :D
Guest RedLineGTR
The best place to fit it would be on the driver’s side of the front bar rather than in front of the transmission cooler. If you see the size of the oil engine cooler it would be pretty hard to squeeze it in near the transmission cooler.
Cheers Rob
As some of you know I had oil leak problems from my sandwich plate. Spoke to them and turns out that the plate had a design fault which was fixed after mine (great) so there shouldn't be any issues any more. I have a new plate so will let you know how I go.
can ypu post some pics of where you have ur installed?
Guest RedLineGTR
Adam some questions :D
1. Did you just get the kit that people are using to fit the cooler in front of the radiator? and you just reloacted it to the drivers side of the front bar? without the need to get longer pipes etc??
2. The Brackets, did you make them up yourself?
3. Did you install the kit first up? or did you get the workshop to fit it??
Thanks Rob
Sorry guys haven't paid much attention to this thread for a bit. A few people want to get these moving before the Sandown track day on Sunday 24th October. So make it clear if you are able to commit to one of these. I am also more than happy to answer anyones questions over the phone (PM me you number)
Next Group Buy.
1. Daz - In - ???
2. Croat - In - Braided, No Remote, Driver Bar Mounted
3. lbfalcon - Interested - Core only and pushlock hose
4. INASNT - In - Pushlock, No Remote, Driver Bar Mounted
5. Ronin 09 - In - Braided, Remote
6. Coxy_ - Interested - Remote, ?, ?
7. RedLineGTR - Interested
8. R31Nismoid - Interested
If you are definitely in Please PM me asap with the following details:
Car Type
Braided or Pushlock
Remote Filter Relocation or not
Intended place of oil cooler mounting
Shipping Location
Prefered payment method
Ta, Chris.
RedLineGTR - You need to make these brackets up yourself, they are not part of the kit, as every car is slightly different. These cost me about $5.50 for steel and bolts. Can give advise on this if needed.
Guest RedLineGTR
Chris any chance you can answer this question??
Cheers Rob
No Probs Mate,
Adz mounted his in the drivers side front bar. Al mounted his in front of his radiator as there was very large cooler pipes in the way. Both bought similar kits in that they were pushlock and 1.5m of hose. The only difference was Al went for 4x 45 degree fittings as we thought this would make fitting easier. Adz went with 2x 45 and 2x 90. (which is std kit)
The 45 degree fittings are slightly more than the 90's and pushed the price up slightly. You can decide which fittings would suit you best, or we will recommend which ones you go for. Straight fittings are cheapest, then 90's, then 45's.
Hope this helps
People can pay Meridian directly, but please let me make sure we have 5 confirmed before attempting to make that payment. After last time I found it was best to record everyones details on a spreadsheet including exactly what their individual requirements are and get Toby to contact you when he requires the payment. Or if people feel more confident in getting me to handle the money for them, i'm happy to do this too.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
