  • Replies 219
What does the probe look like? Might be hard to get it in cause all the fittings are designed to be very tight.  It would be worth while speaking to toby about that.  I'd say he would have some good sugestions.
Just found the probe is missing from the farking apexi box!!!
***KKKKK
Can we buy it without the oil cooler core?
Ed - If you give Toby a call and let him know exactly what you need he can supply it. All parts of the kit can be bought seperatly. We wont however include this as part of a group buy.
Phone:
03 9553 4200
Email:
Sales: [email protected]
Well, i finally just had everything fitted, and all is sweeeeeet! :cheers:.
No leaks, had plenty of hose and all is mounted solidly. Will post pics once car is back from Centreline Suspension.
Almost ready for the track :P!
I got it installed for a good price, as he is my regular mechanic and i got it done with a whole heap of other things. But i did ask him how much to install, as my mate is considering getting it done, and he said $150 drive in/drive out. That's for materials (brackets, bolts, etc), labour and powder coating (brackets).
Car still at Centreline, so i will post pics later this week.
How long did it take?
About 4 hours ... including making the brackets, running and cable tying the hoses, connecting the speedlock fittings and clamps, changing oil filter, fitting the bitch of a sandwich plate and refitting the front bar. :P
4 hours and alot of piss farting around :(
Mostly by Daz :(
I can say this oil cooler kit works very well on the track, my oil temps were below 100° all day at Sandown on Sunday and it was quite a warm day.. good stuff :(
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
