  • Replies 219
The main advantage is the ability to use a larger oil filter and increase the oil capaciy of the car. Also can make it easier to change the filter and from what I've seen with my install it makes actualy fitting the adapter easiert too!
A thermostat is useless unless you live in the snow, no one has used one.
Why is it an advantage in having a remote oil filter?
The oil filter on a Skyline (GTR especially) is hard to get at, and makes a big mess when you change it (oil goes all over side of engine and suspension). A remote filter "moves" the filter to the strut tower, so you can put an ice cream bucket under the oil filter, and undo it easily and not make a mess.
Why would you need a thermostat?
If you live in a cool climate then the oil going through an oil cooler permanently could result in the oil not reaching operating temperature (ie your oil would always be cold). This can have a nasty effect on bearings and turbos as the oil would be too thick. A thermostat oin the line opens the oil path to the cooler only when the oil termpature is high enough. Works exactly the same way as your car radiator thermostat; keeps you engine at the same temperature.
Have been reading these threads about the oilf coolers and they are confusing me stupid!
Hope this helps.
Helps a great deal thanks. Is there enough for another group buy of 5? I am interested in one for a gtst, with braided lines...
Ask Scotsman. Personally I'm looking at two options for around a grand:
- HKS full kits including cooler, thermostat relocator, mounting hardware
- UAS kits including cooler, thermostat, relocator, mounting hardware, air baffles to direct air (BoostedZed =UAS is getting the production run costs finalised)
Trust33 - Yes I would definately oil the O ring as it will stop it from ripping or overlapping as it is tightened.
Croat - I believe there are three others interested at this stage. when five or more are there we can arrange another buy. No you dont require a thermostat in Australia unless you live at the top of a snow field and you car is naturally aspirated. Turbo cars have no problem getting up to opperating temps on a cold day even when you take it very slowly in the morning. As you know turbos uses exhaust gas to run, which heats oil very quickly.
Here's some pics for you punters!
Also we found out on the track day at PI that if yours is mounted in the guard you need to allow for air to flow through the cooler. I did this by drilling some small holes into the plastic guard. But EMRE had a better solution, which was to replace part of the plastic insert with an r33 gtst guard as this already has factory air flow holes that are pointing down to stop stuff getting into the guard.
I will do this also when I can get a hold of one. As it was worth 10 degrees or more on the track.
Scotsman put me down for 1 of these, I have $$ ready to go.
Oil Cooler Kit without remote filter (Pricing based on enough hose to mount in drivers side front bar.
Blue Pushlock Hose: Retail $550, 15% $465, 20% $440
I will need it in the next few weeks latest to get ready for sandown track day
Guest RedLineGTR
just wondering if anyone has installed one of the oil cooler kits on the drivers side of the front bar?? (GTST) since i will be getting a FMIC that the pipes return to the stock pipes and i have no issues with fitting it on the drivers side, Cheers Rob
Bugger it put me down for the group buy. I have already spoken to the boys at meridian and they are fitting it.
Cooler, braided, remote. Retail $1025, 15% $875, 20% $825
Can I pay meridian directly, as they're fitting for me?
Cheers Chris
Guest
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
