  • Replies 219
Yeah rob what he said. The kits were measured out to give you enough hose to fit it in the front bar. I fitted it in the gargae at my place and just used some aluminium to make up the brackets. Mine is the standard GTS kit.
Nope....
Have got 3 pm's for definate's. If you speak to or can speak to any of the other interested parties please do, as the track day will sneak up on us quicker than you expect and we should get this moving.
1. INASNT
2. Daz
3. Ronin 09
Ok, Email sent to Toby awaiting reply for stock levels and confirmation of pricing.
1. INASNT
2. Daz
3. Ronin 09
4. Croat
5. GTTR34
If there is anyone else please PM me ASAP.
Toby has advised that he will have all the parts for everyones kit by Monday.
He has told me to pass on that the $440 price will include 2x Straight Fittings and 2x 90 Degree fittings, a cooler, billet adapter, and 2.5m of hose.
I think that the 2x 90 will go on the cooler if mounting in front bar and the 2x0 can come out of the block providing nothing is in the way. If you think you will require 2x45 instead of 2x0 for this then the price will increase slightly.
Al found that the 4x45's were the way to go for mounting in front of radiator. But people can feel free to make up their own minds about what fittings they require and Toby will adjust the price accordingly.
I think that the straight fittings will suit most people. But you should have a look at your own engine bay and decide.
Dumb arse question from the guy from the back:
When i do an oil change, how do I ensure that
1. the cooler is drained of oil?
2. the cooler fills back with correct quantity of oil once I have changed the oil?
:P
Will let you guys know as soon as Toby is ready to go. I want to confirm everything with him before getting money in case there is any slight price change.
When I change my oil I will have to disconnect the cooler and turn it upside down to empty it of oil. But I wasn't going to bother too much. I change mine quite often anyway. There is no prolem with mounting the cooler upside down, which would make empting easier. But then filling it up on startup after the oil change would be harder work for your engine. When putting the kit together I would recommend filling the core with oil before connecting the hoses to help eliminate any surge issues. But two seconds after your car starts the cooler will be full and will stay full all the time, unless it's mounted above the oil level. In the case of mounting it in front of radiator it may get some drain back over time.
Which ever way you decide to mount it will work fine. After installing a cooler I'd say wait a lot longer before driving off once the car is started to make sure oil pressure is up. Dont just start and go staight away.
Ok Toby has all the parts required to make all the kits.
If anyone needs to change to 2x45 degree fittings over the original kits straight fittings there is an additional $46 cost
Ronin09 and GTTR34 - Please contact Toby directly to arrange payment ([email protected], 03 9553 4200.)
INASNT, Daz and Croat you have PM regarding payment.
Spoke to Toby yesterday, my car is being fitted up on Friday :)
Cheers Chris
EDIT - cooler fitted... bit*h of a job apparently.
32GTRs suck to fit anything to!
Haven't given it a cane yet, but will do on weekend
What does the probe look like? Might be hard to get it in cause all the fittings are designed to be very tight. It would be worth while speaking to toby about that. I'd say he would have some good sugestions.
Guest
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
