worth playing, but if its not your thing, its not your thing..
Like skyzerr33 is saying, not much too it really.. and if you want a more complex shooter there are others around. Anyhow, its keeping me playing. I'll probably endevour to finish it, and I don't finish too many games.
Works on older systems and scales pretty well down to older systems, but you only get 640x480 and medium or low settings. Meant to be ok, but would take away a fair bit of the atmosphere in a game like that i reckon.
runs nicely on mine with high detail with 1024x768 w/ Athlon XP3200+, 512mb RAM, and 9800pro extreme overclocked to above 9800XT speed. Wouldn't want much slower than that to get the full effect.
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-969548
My day at work today:
Install 256MB NX6800 card.
Install Doom III
....errr......something goes here....bit of a blur really :D
Stop playing Doom III
Went home from work.
I like it but would prefer the system our video card rep plays it on:
Athlon 3800+
2GB RAM
400GB S-ATA HDD
Abit 512MB Vid card
In ULTRA quality (or whatever it's called) @ 1600x1200 at 68FPS !!!!! FARK!!!
Adrian
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-969610
lol got to try it waiting to get it off mate Shound go good on my
set up of
P4 3.0 ghz800mhz fsb @3.4ghz
Geil PC 3200 DDR ram 1gig dual channel
MB Abit IC7 MAX 3 i love this board
ATI HIS 9800 Pro IceQ @ past XT speeds
Housed in Thermaltake Xaser III 2000A
550 watt Antec True Control
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-970674
later this year i plan to buy my new PC from a friend who builds custom PC's with these specs:
3.4 Ghz Processor
1 GB DDR RAM (more if financially + physically possible)
200 GB HDD (need space for my muzyk)
17 inch LCD display (thinking about 19 inch)
8 speed DVD burner
And some other wierd computer gizmo's which i have no clue about...
He quoted me $2200 - $2500... is that a decent price??
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-971877
    • This is a real nostalgia trip for me, I mean SK Bilsteins? I ran those lol Good times.  Good work Duncan, it's not an easy job in many respects. I'm sure the family appreciates it.
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
