2 minutes ago, silviaz said:
Wait what? Are you sure? I heard no noise and I checked with an endoscope the pistons look the same.
You won't hear a noise and in the case of a mis-timed engine turning over the contact is not normally large enough to leave a large mark or damage, but is enough to bend valves
How do you explain the extra resistance when turning over at some points? With plugs out it is the same to spin an engine over, no Change in resistance
ah fml, so to confirm this should I get an mirror for my endoscope to check if the valves are bent?
9 minutes ago, Rusty Nuts said:
No, thats a compression tester, you will need an air compressor but a small one will work fine
https://www.supercheapauto.com.au/p/toolpro-toolpro-cylinder-leak-down-tester/392419.html
Ok ill put my engine to tdc on the silver links and do it. I assume thats the correct procedure.
Edited by silviaz
19 minutes ago, Rusty Nuts said:
you need to do all cylinders at TDC  your firing order is 1 3 4 2 so rotate one full turn after no.1 then do 3 and so on. check out some youtube vids if you haven't done one before.
I see thanks will go from there.
17 hours ago, Ben C34 said:
I would do a leak down test, or just put compressed air in and listen if it is leaking out the valves, no mirrors.
Hey man so I've set up everything and I am not touching anything anymore until a mechanic comes I'll get them to do the leakdown test since they will probably have the tool will save me some money. I also called a couple of mechanics and they said about the resistance it can happen cause pressure builds up or like you said because valve touching piston. In this vid on the first time I try to crank it, it's very tight then it's ok then it's right towards the end. This is what you're referring to right?
35 minutes ago, Ben C34 said:
If the spark plugs are out there is  no resistance to build up. It definetily seems from here you have likely bent valves. Hope not but that would be a long shot
dammit.  Maybe jobs like these in the future leave for someone more qualified. I would have thought following the manual would of been enough lol.
On 12/11/2019 at 8:32 PM, Rusty Nuts said:
You have been struggling with fix since early November, you probably need to get someone knowledgeable in front of this engine to help you.
Four days ago I suggested you get some help, but you were not having that!!!!!
I did I called a mechanic, and he said it was ok to crank the engine so I did. Just leaving the rest now for the mechanic. They are just busy as hell will be waiting a bit until I get my hands on one.
I also read back when you wrote about how I didn't have the marks lined up when I started I see what you mean now. I referred back to the manual and while it did say rotate to tdc I didn't realize the links were supposed to be there as well.
Edited by silviaz
Great news!! Got the mechanic he didn't have to take the timing cover off,  and did the compression test had 190-210 across all cylinders. Which seems quite high service manual says 156. But cranked it didn't have any usual noises. Tomorrow will be the test to see if it turns on fine.
  • Like 1
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
