On 12/17/2019 at 9:20 PM, Rusty Nuts said:
Great news indeed, had my fingers crossed for you mate, hope it all works out well, Happy Days.
Mate I turned it on and she sounds great. Here is a clip. Thanks again for all your help, lots learned on this project. Does have some smoke I think cause the old gasket but getting a mechanic on Monday again to double check everything, and just gotta bleed the valve for the coolant as there is still air bubbles. I drove in reverse and the car didn't turn off! And it seems like the clutch is working better now? I don't hear any crunching, (though I didn't operate the car but I could always here it outside). Anyhow, here it is! (at the 0:22 mark it starts to idle)
sil-Copy.mp3
On 12/11/2019 at 11:18 AM, Rusty Nuts said:
Follow the procedure in the workshop manual, guaranteed to work.
get manual,   http://www.eatsleepboost.lt/files/manuals/s14_200sx_sr20det_repair_manual.pdf
Hey I found out what the entire problem of the car was. The idiot who owned the car before me put the boost to maximum. That was legit the only thing that caused the car to stall, turned it down and works like a dream. Wasn't even the broken rocker arm it looked like lol.
Sounds like you are enjoying driving your Silvia mate, really glad it all worked out well, Happy Xmas.
Hey mate,thanks. Happy Xmas to you to.  Thanks for everything.
Edited by silviaz
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
