WTB - Transfer Case Steel Ring / Friction End Plate
Hi Everyone
I'm in a bit of a pickle. I need the end plate in the transfer case. Circled in the picture.
These steel plates come in various sizes to set the clearance. I need it to be 6.7mm / 6.8mm thick.
Can anyone help? I will pay up front and need it to be posted fairly quickly.
Thanks
You will not get this quickly. These are special order part from Japan, we've done heaps of transfers and wait time is at least 8 weeks generally as they are made up from Nissan. Also needing to go to 6.8mm on the front retaining plate (31537XA) suggests that the rest of your friction and / or steel plates are excessively worn, as we've never needed to go past 5.2mm - 6.2mm, and that's using the standard 7 friction plate or modified 10 friction plate arrangement. These plates go up in 0.2mm increments from 4.8mm - 7.0mm, so a 6.8mm is definitely not the norm.
The rear retaining plate should always be set to 5.0mm (31537X). Are you checking clearance correct as in, you have the Attessa actuator with piston installed in the back ? If not it gives an inaccurate and much larger clearance, which should be between 8 - 20 thou (0.2mm - 0.5mm) between front retaining plate and retaining circlip.
I have some front retainers from 5.8mm - 6.2mm and lots of the steel plates, but if you definitely need the 6.8mm retaining plate the original part number is 31537-05U10 which has now been superceded with 31537-1P410 and is about $90 -$110.
For any other thickness the part number changes with the last two digits from 00 to 11, so a 4.8mm is 31537-1P400, a 6.0mm is 31537-1P406 and a 7.0mm is 31537-1P411.
Hope this helps.
Hi BK!
Thank you very very much for this long and informative post. I am going to double check with my mate that is rebuilding the transfer case and see if there is something wrong. I am building it with the new arrangement (most aggressive, s/f/s/f/s/f/s/f/s)
I already have a 5.0mm and 6.2mm retainer, but he thinks he needs 6.7mm.
I have purchased brand new friction plates, but have reused the steel plates. Maybe that is the cause of the large clearance - re-using the steel plates?
What are the steel plates meant to be thickness wise?
Thanks again mate, I really appreciate this input.
OK so you're doing the 10 plate mod. Can't remember the steels off the top of my head but they usually don't wear bugger all (less than 0.05mm), UNLESS the wrong oil or low oil has been in there. Castrol Transmax Z is the best, I'll measure one later to confirm steel thicknesses, but very rarely need to replace the steels. As above the clearance is 0.2mm - 0.5mm, and they only come in 0.2mm increments so there is no 6.7mm.
Buying new plates has generally decreased the clearance required, so it shouldn't be that.
As mentioned above, very important - make sure the clearance is being measured with the Attesa actuator installed with piston in. This is a must or else your clearance will be wrong (on the large side).
Yeah that is it I am pretty sure. (I am just a dumb tuner, I'm not doing this, my friend who is a mechanic is lol )
This is a donor case so I have no idea how it was treated before I got it. It's from a R33 GTR so it is possible someone stupid was pulling the fuse and doing skids not knowing these have preload.
I have only used Transmax Z in both of my GTRs transfer cases so glad to hear that.
This one we are building is for a circuit car hence the 10 plate mod.
He has also assured me that he is measuring it with the Attesa actuator installed with the piston in.
Just curious, when you say "piston in" does that just mean the actuator bolted onto the back with no hydraulic pressure? (at rest if that makes sense)
Image result for attesa actuator
Yes, the actuator bolted on the back of the transfer with the piston rod for it also installed with no hydraulic pressure on it. This is the real disengaged state. It does make a difference to the clearance, and the Nissan manual also mentions to check it like this. If you don't do this and measure it, reset to the 0.2mm - 0.5mm clearance with the actuator not installed, then bolt the actuator up the transfer case will be permanently locked to some degree, drag the plates and destroy them.
I just asked him and he said that is exactly how he has done it.
I guess now all I need to do is measure the thickness of my steel plates and see how much they are worn.
If you have some there and can give me a measurement that would be great :)
4 minutes ago, BK said:
I'll look into it. More importantly, what is the measured clearance now ?
He says it is 0.9mm at the moment.
I'm starting to think my steel plates are all worn that slightest amount. All the friction plates are brand new.
Just to add to this mate - I contacted Kudos Motorsport earlier and they said the plates are 2mm thick.
He has 12 in stock so I might be able to grab some if they are the issue.
Thanks for your help though.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
