WTB - Transfer Case Steel Ring / Friction End Plate
Hi Everyone
I'm in a bit of a pickle. I need the end plate in the transfer case. Circled in the picture.
These steel plates come in various sizes to set the clearance. I need it to be 6.7mm / 6.8mm thick.
Can anyone help? I will pay up front and need it to be posted fairly quickly.
Thanks
You will not get this quickly. These are special order part from Japan, we've done heaps of transfers and wait time is at least 8 weeks generally as they are made up from Nissan. Also needing to go to 6.8mm on the front retaining plate (31537XA) suggests that the rest of your friction and / or steel plates are excessively worn, as we've never needed to go past 5.2mm - 6.2mm, and that's using the standard 7 friction plate or modified 10 friction plate arrangement. These plates go up in 0.2mm increments from 4.8mm - 7.0mm, so a 6.8mm is definitely not the norm.
The rear retaining plate should always be set to 5.0mm (31537X). Are you checking clearance correct as in, you have the Attessa actuator with piston installed in the back ? If not it gives an inaccurate and much larger clearance, which should be between 8 - 20 thou (0.2mm - 0.5mm) between front retaining plate and retaining circlip.
I have some front retainers from 5.8mm - 6.2mm and lots of the steel plates, but if you definitely need the 6.8mm retaining plate the original part number is 31537-05U10 which has now been superceded with 31537-1P410 and is about $90 -$110.
For any other thickness the part number changes with the last two digits from 00 to 11, so a 4.8mm is 31537-1P400, a 6.0mm is 31537-1P406 and a 7.0mm is 31537-1P411.
Hope this helps.
Hi BK!
Thank you very very much for this long and informative post. I am going to double check with my mate that is rebuilding the transfer case and see if there is something wrong. I am building it with the new arrangement (most aggressive, s/f/s/f/s/f/s/f/s)
I already have a 5.0mm and 6.2mm retainer, but he thinks he needs 6.7mm.
I have purchased brand new friction plates, but have reused the steel plates. Maybe that is the cause of the large clearance - re-using the steel plates?
What are the steel plates meant to be thickness wise?
Thanks again mate, I really appreciate this input.
OK so you're doing the 10 plate mod. Can't remember the steels off the top of my head but they usually don't wear bugger all (less than 0.05mm), UNLESS the wrong oil or low oil has been in there. Castrol Transmax Z is the best, I'll measure one later to confirm steel thicknesses, but very rarely need to replace the steels. As above the clearance is 0.2mm - 0.5mm, and they only come in 0.2mm increments so there is no 6.7mm.
Buying new plates has generally decreased the clearance required, so it shouldn't be that.
As mentioned above, very important - make sure the clearance is being measured with the Attesa actuator installed with piston in. This is a must or else your clearance will be wrong (on the large side).
Yeah that is it I am pretty sure. (I am just a dumb tuner, I'm not doing this, my friend who is a mechanic is lol )
This is a donor case so I have no idea how it was treated before I got it. It's from a R33 GTR so it is possible someone stupid was pulling the fuse and doing skids not knowing these have preload.
I have only used Transmax Z in both of my GTRs transfer cases so glad to hear that.
This one we are building is for a circuit car hence the 10 plate mod.
He has also assured me that he is measuring it with the Attesa actuator installed with the piston in.
Just curious, when you say "piston in" does that just mean the actuator bolted onto the back with no hydraulic pressure? (at rest if that makes sense)
Image result for attesa actuator
Yes, the actuator bolted on the back of the transfer with the piston rod for it also installed with no hydraulic pressure on it. This is the real disengaged state. It does make a difference to the clearance, and the Nissan manual also mentions to check it like this. If you don't do this and measure it, reset to the 0.2mm - 0.5mm clearance with the actuator not installed, then bolt the actuator up the transfer case will be permanently locked to some degree, drag the plates and destroy them.
I just asked him and he said that is exactly how he has done it.
I guess now all I need to do is measure the thickness of my steel plates and see how much they are worn.
If you have some there and can give me a measurement that would be great :)
4 minutes ago, BK said:
I'll look into it. More importantly, what is the measured clearance now ?
He says it is 0.9mm at the moment.
I'm starting to think my steel plates are all worn that slightest amount. All the friction plates are brand new.
Just to add to this mate - I contacted Kudos Motorsport earlier and they said the plates are 2mm thick.
He has 12 in stock so I might be able to grab some if they are the issue.
Thanks for your help though.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
