Engine is running poorly, and OBD said that the signal from the MAF was 0.0. I replaced the MAF insert (22680-6N21A), and its still 0.0. Inlet temp sensor works with old and new insert. So either the problem is;
1. ODB misreporting MAF signal, and there's some other issue that doesn't trigger a CEL
2. new MAF is dead
3. wiring issue
I'm starting with looking at #3.There's 5 pins on the connector to the MAF. I've measured resistance to ground with ignition off, and then voltage with ignition on.
Pin - resistance - volts w/ Ign on
1  - infinite - 5
2 - 111       - 12
3  -  0         -  0
4  - infinite   -  5
5  - infinite   - 0
Does anyone know the MAF pinout?
Where is the ECU? I've got an ECU pinout from here, so i could check the MAF to ECU wiring.
  • 4 months later...
