I'm currently in the market for upgrading the clutch and figured I'll go with a 6-puck clutch to get a bit more bite as I'm primarily going drifting. The car currently produces 500nm and I'm standing between getting either an ACT clutch (https://www.autoextreme.co.uk/act-clutch-nissan-skyline-r32-r33-gtst-heavy-duty-race-sprung-6-puk-clutch.html) or a Xtreme KNI24007-1B. I'm currently running a fullface clutch so I'm aware about that there will be more bit with a 6-puck. However, I'm wondering about ACT vs. Xtreme, I've been trying Googling but due to their generic names it's not easy.
As I'm changing the clutch I figured I might as well get a lightened flywheel and it's current standing between a Competition ultralight flywheel (steel, 5kg) or a Driftworks flywheel (chromoly, 8.5kg). 3.5kg is quite a difference but the materials are also different, which I was curious if anyone could provide additional insight to.
Thanks in advance guys :)
I cant comment on the other but I used Xtreme one with chromoly fly for good couple of years drifting with similar / more power and did the just just fine !
Dont know where you live but currently using NPC - they built a single plate to my required specs - decent $
Unless you've substantial power upgraded, any clutch will do that is not stock to a degree like what you've mentioned. Until you're going to a multiplate, whatever really. Makes more sense for twin and up as a flywheel change is a given, unlike singles.
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
