I'm currently in the market for upgrading the clutch and figured I'll go with a 6-puck clutch to get a bit more bite as I'm primarily going drifting. The car currently produces 500nm and I'm standing between getting either an ACT clutch (https://www.autoextreme.co.uk/act-clutch-nissan-skyline-r32-r33-gtst-heavy-duty-race-sprung-6-puk-clutch.html) or a Xtreme KNI24007-1B. I'm currently running a fullface clutch so I'm aware about that there will be more bit with a 6-puck. However, I'm wondering about ACT vs. Xtreme, I've been trying Googling but due to their generic names it's not easy.
As I'm changing the clutch I figured I might as well get a lightened flywheel and it's current standing between a Competition ultralight flywheel (steel, 5kg) or a Driftworks flywheel (chromoly, 8.5kg). 3.5kg is quite a difference but the materials are also different, which I was curious if anyone could provide additional insight to.
Thanks in advance guys :)
I cant comment on the other but I used Xtreme one with chromoly fly for good couple of years drifting with similar / more power and did the just just fine !
Dont know where you live but currently using NPC - they built a single plate to my required specs - decent $
Unless you've substantial power upgraded, any clutch will do that is not stock to a degree like what you've mentioned. Until you're going to a multiplate, whatever really. Makes more sense for twin and up as a flywheel change is a given, unlike singles.
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
    • Some of the stuff the PDR guys in the states pull is amazing too. Instead of drilling a hole. They crank some insane tension into it. I actually DIY built a pulling bar myself that I used to pull the Subarus front end out with. About an hour's work, a bit of 30mm *3mm shs, and a piece of 5mm thick plate. Worked great!   But I vote replace it with a GTR rad support. And not going to lie, I'll laugh if a GTR rad support doesn't fit a GTt...
    • Sorry, that was with regards to the rather pretzeled corner of the reo bar. It's in such a state over the years that drilling a hole is probably preferable to bothering to unbolt the thing
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
