You can't know unless you're familiar with the transmissions once disassembled. Coming from GTR boxes (which are the same as R33 Gts turbos Gearset and synchro wise), the only difference will come with the synchros, shift fork and gear with 3rd like 97+ stuff which translates to any FS5R30A transmission. Not sure which years are series 1 and 2 you're referring to in R33 gts,t. In GTR, 89 - 96 is same, 97 -98 upgraded (R33 GTR series 3), but not much of an upgrade really like people make out but are not interchangeable. Old mate Hardsteppa just went through this on a non GTR on this page.
I did indeed. I would say its unlikely you have a series 2 box, as i gather the vast majority are series 1. As above you would need to pull it apart and look at 3rd to see for sure.
this bit circled. So you are extremely unlikely to find a brand new 3rd gear, 4th gear,  2>3 coupler or synchro hub, but should be able to find everything else new.
@hardsteppa thanks heaps
It appears that I have the following options, any advice would be a appreciated
a) rebuild the series 1
b) source a series 2
c) transplant the internals from GTR
The box is being mated to a mildly worked RB26 and then shoe-horned into a 240z street/track car, so its going to get a bit of a hard life and therefore needs to be somewhat reliable.
Around 3g aus i believe. Between buying a box and buying parts for rebuild i spent over 2g, and still have all old gears, beat up casing etc. So all brand new for that price is worthwhile IMO.
  • Like 1
I bought a brand new r34gtt box for 3k at the end of last year when there was heaps of stock. Price rose a bit in the next few months. I have been told recently they are now made to order and it's around a 3 month wait.
  • 5 years later...
On 19/12/2019 at 10:55 PM, GTSBoy said:
Let's just suggest that the differences are insignificant. Just because it has a different part number doesn't mean it's functionally different.
If you call a completely different improved 2nd>3rd  synchro setup insignificant then, ...yes.
Just finalising an R34 RB25 gearbox swap into R33, couple of things to note.  If you are going with a push-clutch rather than the R34's pull, there are bosses moulded into the bellhousing you need to drill and tap to be able to bolt your clutch slave cylinder on. I put a stud into the hole closest to the clutch fork to make installing the slave easier, but up to you.
You need to change the front cover plate....obviously, as it's well-covered everywhere. If you were short of $$ looks like you could adapt the R34 front cover to be able to take the clutch fork ballstud/pivot bolt but, up to you, prob not worth it.
The neutral and reverse plugs on the sensors that the box comes with are likely to be different. You can get the loom side of the connectors here, and they are EXCELLENT quality.
https://www.efisolutions.com.au/2-pin-grey-connector-nissan-reverse-switch-fuel-ha
https://www.efisolutions.com.au/2-pin-black-connector-fits-some-nissan-neutral-swi~138383
The box comes filled with oil but it is a corrosion-protection oil only, do not run the box with it. Drain and refill with a good 75w-90 once box is installed.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
