hi there,
i bought a AP900Ci which i got cheaper from a private seller. i also ordered a 350Z T-wire to make it a plug an play kit but once reading the instructions i´m a bid confused.
what i want is, to use the OEM steering wheel buttons (allready got them used from usa). the instructions for using OEM buttons show a 3-wire and a 4-wire diagram. the problem is, that the Stagea OEM buttons does have just 2-wire.
i don´t want to use the liteon control stack. i want to use just the steering wheel buttons. any idea?
i know this thread: https://www.sau.com.au/forums/topic/384164-fs-cruise-controls-for-m35-v35-diy-install/page/6/#comments
and from what i read it seams to be possible to use just the steering wheel buttons for "main functions". did anyone installed the AP900 by himself or had the instructions from Commsman?
did anyone have an idea where to get speed signal from? as i don´t have a USB-data cable to reprogram my AP900Ci i would like to wire it in manually may without can-bus. only signal i wasn´t able to find is speed, as ECU don´t have speed signal wire (it gets it from CAN-BUS).
i read somewhere that the atessa ecu have a speed signal and that there should be a 4-pin plug with speed signal close to the OBD-plug.
if anyone have an information which helps, please let me know. big thanks!!!
did anyone know the wiring of the abs controll unit and where its located? couldn´t find anything on google.
maybe it would be an option to get the signal from one abs sensor.
i read that g35 does have speed signal on radio wiring, no idea if its 100% the same. will have a look tomorrow on my radio wiring.
found a pinout of the abs / ets unit, but didn´t found the location of it. even with nissan fast i wasn´t able to locate it.
but i had another idea today....
BCM should be the unit which converting the speed signal into can-bus signal, isn´t it? BCM is located in drivers side foot room where the fusebox is located. maybe i could get the speed signal from there!?
i found the japanese workshop manual for M35Stagea yesterday and translated all sites to english.
looks like i found a useable speed signal.
i have fully wired the AP900 today. will going to calibrate and test it tomorrow. if it work with this signal i write a short tutorial how to wire the cruise contoller if you don´t want to use can-bus.
the information with the non-canbus speed signal could be useful for other things, isn´t it!?
Edited by germanstagea
  • Like 1
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
