Got a basically stock 99 RB25Det Neo Stagea. Just recently had to replace all the coil packs because one had failed so I got some brand-new spit fires for the old girl. About a week after installing them stated to feel like the car was down on power a little when I got on boost. After driving around for a bit I could tell something was up. first gear almost felt like the car was NA with what felt like no extra power when I got on boost.  Second wasn’t as bad had a little extra power on boost but still nowhere near where it was before. 3rd 4th 5th Also sort of felt off (But it’s kind of hard to tell in the high gears). To sum it up Car feels Absolutely normal driving around normally (Not getting on boost). But as soon as you get on boost there is no power. The car sort of hesitates and throughout the rev range the power will tend to fluctuate come in and out a little bit. I’ve been driving it sparingly for the last week and have also noticed that some days it feels like its NA with almost zero power. Others its not so bad. And one day this week the car feels almost normal. So, it’s a little intermittent. Not too sure what’s going on
My first reaction was "it’s probably just a boost leak" but my boost gauge was still siting on 12psi like normal and I’ve got the reference line for it coming directly from the intake manifold so there’s no funny business going on in between.
Other Thought was it had something to do with spark.  so, I got all new sparkplugs and just got a brand-new set of coils.  I just left the plugs with the stock 1.1mm gap and tested each coil pack/coil pack wire and plug to see if I’m getting a nice blue spark which I am. So that’s crossed of the list
From what I can tell I must have something to do with fuel. Not sure exactly what could be only guess is dying pump, blocked fuel filter, blocked injectors. Note about 3 weeks before all this I used some of that liquid injector cleaner that you put in your fuel tank. possibly dislodged a bit of gunk somewhere in the fuel system and is causing issues?? I have no real way to test the fuel pressure let alone the whole system. Haven’t really messed around much with fuel stuff all that much in my time so any ideas or tips or tricks for trouble shooting would be greatly apricated.
Could it be possible something is stuffed with the ecu???
https://www.sau.com.au/forums/topic/479434-loss-of-power-in-boost/
Can still be a boost leak.
Turbo will be working its   guts out, heaps hotter intake air and higher back pressure..
to test for boost leaks you need to pressure test.
My vote is boost leak.
Hhmm Yeh could still definitely be possible. I might have to look into a pressure test. Still it’s a substantial loss of power just for some higher intake temps. Plus its only the stock turbo and I’ve already got it basically maxed out at 12psi. If it had to work any harder it’d probably disintegrate.
Replace the fuel filter under the bonnet. Cut it open to see if it is full of crap. While its off turn on the key to see if a decent spurt of fuel comes out. You really need a fuel pressure gauge.
Pressure test the system ...make up a plug with a tyre valve in the end and put it in the  outlet pipe from the turbo and see if it will hold 20 psi.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
