Got a basically stock 99 RB25Det Neo Stagea. Just recently had to replace all the coil packs because one had failed so I got some brand-new spit fires for the old girl. About a week after installing them stated to feel like the car was down on power a little when I got on boost. After driving around for a bit I could tell something was up. first gear almost felt like the car was NA with what felt like no extra power when I got on boost.  Second wasn’t as bad had a little extra power on boost but still nowhere near where it was before. 3rd 4th 5th Also sort of felt off (But it’s kind of hard to tell in the high gears). To sum it up Car feels Absolutely normal driving around normally (Not getting on boost). But as soon as you get on boost there is no power. The car sort of hesitates and throughout the rev range the power will tend to fluctuate come in and out a little bit. I’ve been driving it sparingly for the last week and have also noticed that some days it feels like its NA with almost zero power. Others its not so bad. And one day this week the car feels almost normal. So, it’s a little intermittent. Not too sure what’s going on
My first reaction was "it’s probably just a boost leak" but my boost gauge was still siting on 12psi like normal and I’ve got the reference line for it coming directly from the intake manifold so there’s no funny business going on in between.
Other Thought was it had something to do with spark.  so, I got all new sparkplugs and just got a brand-new set of coils.  I just left the plugs with the stock 1.1mm gap and tested each coil pack/coil pack wire and plug to see if I’m getting a nice blue spark which I am. So that’s crossed of the list
From what I can tell I must have something to do with fuel. Not sure exactly what could be only guess is dying pump, blocked fuel filter, blocked injectors. Note about 3 weeks before all this I used some of that liquid injector cleaner that you put in your fuel tank. possibly dislodged a bit of gunk somewhere in the fuel system and is causing issues?? I have no real way to test the fuel pressure let alone the whole system. Haven’t really messed around much with fuel stuff all that much in my time so any ideas or tips or tricks for trouble shooting would be greatly apricated.
Could it be possible something is stuffed with the ecu???
https://www.sau.com.au/forums/topic/479434-loss-of-power-in-boost/
Can still be a boost leak.
Turbo will be working its   guts out, heaps hotter intake air and higher back pressure..
to test for boost leaks you need to pressure test.
My vote is boost leak.
Hhmm Yeh could still definitely be possible. I might have to look into a pressure test. Still it’s a substantial loss of power just for some higher intake temps. Plus its only the stock turbo and I’ve already got it basically maxed out at 12psi. If it had to work any harder it’d probably disintegrate.
Replace the fuel filter under the bonnet. Cut it open to see if it is full of crap. While its off turn on the key to see if a decent spurt of fuel comes out. You really need a fuel pressure gauge.
Pressure test the system ...make up a plug with a tyre valve in the end and put it in the  outlet pipe from the turbo and see if it will hold 20 psi.
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
