Billyboy369 Posted December 28, 2019 Share Posted December 28, 2019 Hey guys probably a stupid question but I was just wondering if I could fit larger rotors on my R34 GTV while keeping the stock GTT callipers, I’m running 18” wheels and want to fill them as much as I can I’ve heard 355mm would fit snugly but would like to keep my callipers as I like the stock look any help would be greatly appreciated Link to comment https://www.sau.com.au/forums/topic/479454-larger-rotors-stock-callipers/ Share on other sites More sharing options...
KiwiRS4T Posted December 28, 2019 Share Posted December 28, 2019 Yes you can get adapters to push the calipers out ...but that is hardly a stock look. Link to comment https://www.sau.com.au/forums/topic/479454-larger-rotors-stock-callipers/#findComment-7921964 Share on other sites More sharing options...
Duncan Posted December 28, 2019 Share Posted December 28, 2019 And adapters are specific to a source model and target disc size, so your specific combination may not exist off the shelf Link to comment https://www.sau.com.au/forums/topic/479454-larger-rotors-stock-callipers/#findComment-7921968 Share on other sites More sharing options...
GTSBoy Posted December 28, 2019 Share Posted December 28, 2019 ^^This. I was going to say that unless it is one of the 2 or 3 very common conversions, you will have to design and make the adapters. Link to comment https://www.sau.com.au/forums/topic/479454-larger-rotors-stock-callipers/#findComment-7921979 Share on other sites More sharing options...
Ben C34 Posted December 29, 2019 Share Posted December 29, 2019 And to add to all sensible advice above, when using the same callipers the chances of being able to do what you plan are slim. Typically only works when going from a really small to much larger rotor to give space for adaptor bracket, smaller diameter changes pretty much can't happen. Link to comment https://www.sau.com.au/forums/topic/479454-larger-rotors-stock-callipers/#findComment-7921984 Share on other sites More sharing options...
Billyboy369 Posted December 29, 2019 Author Share Posted December 29, 2019 Okay well I’ll keep an eye out for some, I saw one set of rear rotors with the brackets but can’t find any for the front (only ones that fit a GTR and I doubt they would fit) Link to comment https://www.sau.com.au/forums/topic/479454-larger-rotors-stock-callipers/#findComment-7922000 Share on other sites More sharing options...
