15 minutes ago, Duncan said:
2wd and 4wd front ends are totally different (strut vs wishbone)
Ah, that's not quite true. On all the R chassis cars the suspension design is exactly the same between RWD and AWD cars. Double wishbone (for a flexible enough definition of wishbone). Same upper arms. Same-ish lower arms and uprights. But the lower arms are different between AWD and RWD cars and the uprights are different. As far as I know, it is not feasible to put AWD knuckles onto a RWD front end. I might be wrong about that - but the AWD knuckles are obviously very different, because they have the whole axle thing going on.
I do not know if R33 RWD front knuckles will fit onto R32, but there is a very good chance that they will. Worth going to a wreckers and putting them side by side.
I was thinking similar to Duncan. Probably best to find a way to fit a sheetmetal code ring somewhere and custom a bracket to hold a sensor.
https://www.sau.com.au/forums/topic/479458-adding-abs/#findComment-7921989
I was just schmoozing through the GK-Tech catalogue and see that their fabricated R chassis front knuckles come in specific R32 and R33/4 versions. I don't know exactly what the difference is - but it would suggest that stock R33 probably won't just fall onto an R32. You'll either not win at all, or have to swap a number of other things.
https://www.sau.com.au/forums/topic/479458-adding-abs/#findComment-7922202
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
