Hey guys, i have a 1999 R34 GTV I have been thinking of wiring a tablet in and making a mount for up the top of the dash like the GTR ones and was just wondering what steps would I need to take to get it functioning properly,
I want to replace my three current gauges and just have the tablet displaying all the temps and pressures, would I need to program the tablet in some way or is there an app for it and how would I wire it in so that it actually reads and displays the correct temps
thanks in advance
9 minutes ago, Murray_Calavera said:
This might be relevant to your interests...
https://www.powertunedigital.com/
Not sure if you could do something better for the money.
I’ve thought about something like this but want something that just displays my gauges (water and oil temps & pressure etc etc)
You're gunna need a USB ADC if you want to connect real world gauges to a tablet. And that would require the USB port to be running as OTG, which can make it hard to charge the tablet, so you're going to need a tablet with a separate power port.
The way you've asked your question leads me to think that it is too big a project.
Next problem using a tablet is how do you plan for it to turn on and off on its own.
Using arduino solves the off and on and has many 0-5 v inputs, just need to cook your brain to get it to display nicely on a tft display. (making it display is easy, making it look good is hard)
Nissan Datascan software has some of what you want but won't show pressures. It'll give you most other sensors though and has some useful diagnostic features. I sometimes use it on a cheap 8" Windows 10 tablet with a bluetooth dongle in the consult connector and charge off a USB cigarette lighter adapter. I just velcro it to a removable block of wood that slips tightly into the slot/tray below my single din stereo. No fancy on/off control though. There's also a lite android version of NDS which should work nicely with a double din android head unit instead of customising the dashboard.
Definitely won't. That is absolutely the way to go, as you can program it to display what ever you want. It'll be heaps better than using a tablet ! Pretty cheap too, my Haltech 52mm CAN gauge cost more than this street dash.
I've got on e in the race car connected to a link G4+. Very user friendly but they have ben raising their prices lately. Have a look at realdash app https://realdash.net/index.php as can use a Doudle Din stereo running on android to display what you need. I'll be using this soon on another project.
I think it is unclear whether any of these options presented above (Realdash, PTD's dash) are able to handle arbitrary analogue inputs (like oil pressure). I was under the impression that they were mostly aimed at ECU data over the diagnostic interface, with limited other inputs (speed, etc). If the ECU don't know about it - the dash can't.
Correct
I emailed them in august and that was the response. If that gets updated to allow 5v inputs direct to it it will be great.
this may be helpful as well.
https://www.facebook.com/groups/tunerstudiodashboards/
another option is go buy a raspberry Pi and test board and start fiddling with that . I am sure someone out there has done it and can help or go buy a Link r34 pnp, add sensors and go that way.
It's a bit of a hassle having to DIY.
The Pi option is nice because it is easy to drive a proper screen from it - even a touchscreen. But then you have a Linux (or maybe Android) environment in which you have to cobble together your DAQ and presentation yourself. That's a project for people who can program or people who know how to leverage other people's programming and have no fear of bolting software elements together.
An Arduino would be arguably 11ty times easier to grab the analogue signals and do some simple processing. But the presentation side could be a right pain. Big colour LCD screens are not so simple to do with Arduinos.
Maybe the compromise is a little from column A and a little from column B. Use an Arduino to grab the data and present it via I2C or some other (likely more interconnect friendly) protocol to a Pi or a tablet. Still have to cobble together the presentation side unless you can impose on one of the dash crowds to come to the party.
3 hours ago, Ben C34 said:
This guy knows how to do it!
See the thing is I like my stock dash and just want one set up just like the GTR M.F.D where it displays useful information and can keep track of peak values, I could use the stereo idea but would need a way to get it to work with iPhone (I have both Apple car play and android auto though) would it be easier to install one from a GTR,  but would want a way to change the GTR symbol to a GTV one or even just R34 (im against any GTR badge in anything other then a Genuine GTR
In that case I can say it is 1000000 percent not going to happen for you.
How much are you prepared to spend? You could buy an aftermarket ecu and grab a dash, a Haltech ic7 would work perfectly. A couple of the stock displays show values only, check out the YouTube video around 3:20 to see what I mean
I'm definitely going to have a look at this set up so far is closest to what I want, if it stops the dash working ill just have to deal with it
Yeah I know, things have escalated quickly lol.
I just figured this option was worth mentioning when he said he wanted a setup similar to the R34 GTR unit, so I thought he was looking for a really neat and clean setup.
  • Like 1
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
