Something I've been meaning to ask for a while - I have deleted HICAS via a GKTech lock bar and ages back I bought a TOG (standard ebay type) hicas delete kit which is still sitting in its box in the garage. The kit looks solid but a few things I don't see as beneficial - first of all the toe arms are the same as your camber/traction arms, as in you turn the middle section and it shortens/lengthens from both ends at once, and is a fairly coarse thread. The stock tie rods are a finer thread, and will give a much more precise adjustment turn for turn than the delete kit arms.
Also on the hub end, the stock ball joints appear to maintain a better angle during up/down movement > less bump steer, with the ball joint pin allowing sideway deflection while still being " fixed"...and  replacing with a poly bush bolted to the toe-arm will turn the hub more, aka inducing bump steer.
What's the arguments to the benefit of going with the delete kit, apart from it being a more solid setup?
https://www.sau.com.au/forums/topic/479472-hicas-delete-kit-query/
Dunno. I went with a complete non-HICS subframe and therefore used the Nissan arms. I think a decent delete kit would use a spherical joint rather than a poly bush. I'm not sure that you need all that mush precision to set the rear toe. The coarser thread should still enable you to get the measurement you want.
If you have a quality delete kit, it will be much stronger then the Nissan rod ends.
I destroyed a brand new set of Nissan rod ends in less then a year, granted my car does get tracked/drifted. I haven't had any issues since putting in the delete kit.
GKTech sell a HICAS delete bar that "has mounts for regular toe arms in the exact position they are in on non HICAS subframes". Regular toe arms appears to mean GKTech or equivalent, not OEM. The implication seems to be that this is better than other HICAS eliminator kits that alter the inner mounting location?
I installed an ebay type (TAS Autosport) HICAS eliminator kit a few years ago and have had no problems with it street driving. Noticeable improvement over flogged OEM ball joints as expected.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
