Hey guys I'm from Brandon MB, I recently bought a 1993 GTR with my wife. originally imported from b-pro yadda yadda yadda. Its our third gtr but this is the first one that we need a tune on. We have replaced everything on the car from -7's, splitfires with new iridiums, complete wiring harness, water pump, rad, thermosostat, all the sensors, mafs, 02's.  Runs like a dream no issues. although I want it tuned for safety either with or without the mafs ( go haltec).  If anyone has some legit good info on good guy tuners in Calgary please send me there number! I Wanted to take it to vex but didn't get along well with the guys as they told me to put my stock turbos back on because they can make 400 horepower and my -7s were a waste of money. Obviously still a great shop not bashing them just not going that route.  thanks boys happy new year. ill get some pics up of her very clean black 1993 gtr. feel blessed.
Thanks we have worked hard to finally be able to get into another gtr. I’ve blown the ceramics before at 1 bar. -7s spool awesome And sound great. just need someone to tune it now for safety and a better power curve, any tuners in Calgary or Medicine Hat that know these cars help a bro out? I don’t care about power just want a safe tune and want to use haltec and delete my MAFs.
I was quite surprised when I called vex and they told me my -7s were a waste, probably because I never bought the turbos from them but oh well. They didn’t wanna take my money so looking for someone else now.
ya I've finally narrowed it down to a haltec ecu. my buddy owns the Toyota dealership here and just bought his own dyno for his big power supras. The boys are handy  using the haltec programming.problem solved gunna tune it ourselves as the haltec comes with a great base map. thanks for the help tho. cars ready to rock excited to see how far we can push it
  • 1 month later...
messed aound with the haltec on our dyno for a few pulls got the car running nice with proper air fuel ratios.  still want to bring the car to someone that knows more than I do in the Calgary area.  Ive now talked to a few guys that have mentioned REV'D performance.  seem like good guys on the phone if anyone has anymore info shoot me a pm thanks!
also im willing to go to Edmonton for the tune but really don't have any connections in the area. car is completely setup ready for e85 just need the tuner now.
  • 1 month later...
Hope all is well to everyone in the alberta area through all this virus stuff....hoping to get together a descent car meet closer to September with all the nissans in the Calgary area. if your on board pm me through the months leading up to and lets get a descent crew together and do a Banff run...cheers
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
