Hey guys,
Nearing the final stages of stripping my R32GTR transmission before blasting and powder coat (then new gearbox).
Mostof the hard work is done, but I’m stuck getting the casing separated from the gears (bell housing is already off).
See pics below - basically the 2 metal pieces which attach to/form part of the shifting mech are stopping me from sliding the gears out in both directions as they’re hitting the housing.
I can’t work out how to remove them so the gears can be removed. Anyone have experience doing this? It looks like there might be pins through them, but not sure if that’s unrelated.
Thanks,
Andrew.
https://www.sau.com.au/forums/topic/479511-transmission-disassembly-issue-r32/
Awesome! That was my suspicion. Got the one facing the bell housing out using a skinny drill bit and tapping it with a hammer.
Rear facing one isn’t having any of it though. Persistence?
Any other major hurdles you’re aware of for the rest of the tear down?
@Duncan @GTSBoy
Got them out! Thanks guys.
Any thoughts on removing this unit?
Have all the 12mm’s out. Now looks like there’s a large central hex bolt and 2 star shaped bolts to go, if I’m right. Don’t have either of those bits unfortunately.
@Duncan @GTSBoy and one final question. I think my skills may have now outrun the requirement.
I need to remove the part circled in blue (for powdercoating) and it seems to me that the way to do that probably requires a bunch of bearings (in the red area) will need to be pulled. Does that sound right?
might be time to admit defeat and take it to the mechanic.
I applaud you for having a go, but, Mate, you are so far out of your depth it's not funny. If you are having trouble disassembling a transfer case, you have absolutely no hope of disassembling the Gearset from the centre plate, let alone reassembling it correctly.
Seriously before you stuff something up, put the tools down now and take it to a gearbox place please.
Are you really doing all of this just for powder coating ? Just sandblasting the cases looks heaps better and is more practical. And cheaper.
Taking to a recommended transmission specialist today. It all needs to come apart anyway as the gears will be replaced with either a Getrag or PPG box. Agree that sandblasting looks good, but for the level of build we're doing it needs to be coated. The entire underbody (subframes, arms, diff, etc) has been stripped and will be coated while the car's on the rotisserie for paint.
18 hours ago, GTSBoy said:
Yes, absolutely. The centreplate is the main structural part of the gearbox. Everything is assembled onto it. If you want to powdercoat it, you have no option but for a complete disassembly of the clusters from it.
Thanks mate. Getting it done this week... professionally ?
So I guess "show quality" street drag then. Sequential or auto in the end I guess. 8's is a tall order with a H pattern.
Sounds like a full on chassis up build, can't wait to see it. You got a build thread for it ? Sounds interesting....
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
