Greetings,
Project: Build an RB26DET with all new parts
Goal: Reach 675 whp
Budget: $15,000
Time constraint: Must be done by 10/31/2022, only doing work on weekends or holidays.
Current Part List:
RB26 24U (N1) short block
RB26 05U (Std) Cyl. Head
https://www.sau.com.au/forums/topic/479526-building-an-rb26-from-scratch/
Looking at how he’s written the date he’s American, which will also make his power figure very easy to achieve.
Not sure how far your 15,000 budget is going to get you, you’re probably going to have to keep it fairly simple to stay within budget
675hp on an American dyno can be done on stock motor with the correct bolt ons and someone that can tune well, i.e. torque limit the motor so it doesn't go bang through timing and boost strategies.
Bore & sleeve? Did I miss a 1 in front of the 6? Haha.
As GTSBoy states porting is always worth it . . . . however Rb heads are pretty efficient out of the box.
Realistically if you are paying some one to port a head it will come down to an hourly rate and that can add up very quickly.
Generally the RB26 heads I have done only need blending intake ports for uniformity, port matching manifolds to gaskets to intake manifolds and ( my preference ) knife edging the intake port divider and if your really OCD the exhaust side as well.
$15k is a conservative number, if I need to go over I will. I'm really just trying to build a motor I can beat on but will last me a while.
Im aware that my block is strong (stronger than the standard too) but I could use some suggestions on mods to handle extra power and extend life.
a friend of mine has suggested boring/sleeving a few times - I really don't want to if its not needed
has anyone drilled the oil return to increase flow out of the head?
also, crankshaft recommendations?
I really appreciate all of your help!
Nope. N1 blocks are nothing special. Follow my advice in your other threads to watch the videos.
He's got no idea about RBs, obvs.
Read the oil control thread, as advised.
Stock will do. Any upgrade is an upgrade.
The biggest issue on any RB26 build is the oil pump drive.
Edited by GTSBoy
As already stated, above, N1 blocks are not as special as was originally believed (that hurts!). There is almost zero difference between an N1 block and a standard RB26 block. It comes down to the individual blocks being compared.
If you're going full crazy on this build you may want to consider an RB30 block, if you haven't already that is.
Regarding sleeving your block, that would be interesting for sure and I'd be well keen to see the results, but would likely eat your entire budget (ok hyperbole, but still not worth the effort) for no effect.
You don't need to upgrade the cams, but if you do you can gain top end power for not much outlay and increase in costs. I run 272, 9.1s and I would consider them larger than necessary, but I know of people running less power, with higher lift and duration cams just because they like them. It's really up to you.
And oil control is the big one, really do your research on oil pumps and oil control. If this goes wrong, it all goes wrong. There's heaps of info here and elsewhere online, hit that search button and get into it! :)
Here's my car being built, it cost the last owner more than 15k (US) but no corners were cut.
  • Thanks 1
If I had 15k USD to burn I would do the following:
  • Nitto OIl Pump
  • Oil modifications, head drain/crank vent
  • Sex Spec Sump
  • Basic Forged Piston Rebuild Kit, usual crap, King bearings, ARP it's mum left/right/centre
  • Drop in cams, springs, retainer, etc.
  • V-Cam setup
  • Twin scroll manifold, modern twin twin scroll turbo
  • No gay twin turbos
  • Rest of the money on strippers, cocaine and a ticket to Tomorrowland 2020
  • Like 1
That works out to about 1 stripper. Ugly Thai, possibly ex male. 1 line of coke that might be half chalk dust. And a ticket to the Deni ute muster. Last year's.
  • Haha 4
sounds like more fun that a pair of twin turbos though :D
  • Nitto OIl Pump
  • Sex Spec Sump
  • V-Cam setup
By the time you add machine work and etc there wouldn’t be much change and that’s not taking into account if he also needs an inlet manifold, injectors and etc
15K USD to AUD = ~ $21.8k
Ummm.. maybe drop the V-Cam
For comparison, My 2.8 Nitto short engine (no head) for the blue 32 was around $19k, and only about $2k of that was labour, for machining. That is for rotating assembly, Nitto oil pump, modified Lewis engines sump supplying own sump and reusing my existing 05U block.
More actually if you include the $2k Quaife front diff in sump.... and that's pretty much that $21k gone as worked out above
  • Like 1
And then add cams, springs, valves, guides, lifters, shins, head studs, gasket, port work, cam gears and labor plus any bolt ons, hoses, timing kit, covers and anything else no one has thought of and you’re looking at 30-35aud or 21-24us
Crate lsa is looking pretty good! Can buy 3
Rather BMW M4, OTS MHD flash, turbo back exhaust, larger W2A IC and run 10s with super low mph then run better times around Wakefield Park with just semis and climate control on.
Budget 80k AUD there is no such thing as building a half spec motor, must be big spec OK . And for all the fruit around it add another 50k onto that for a full package. GTRs are big money so you’ll have to cop it on the chin m8
dont want a hamburger with cheese you want a hamburger with the LOT
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
